Due to some class rules, Delrin steering rack bushing
Former Vendor
Well I was informed that some classes in the SCCA require that bushings can't be Metal. So I made up some using the best Delrin I could find. They look the exact same as our Alumium ones, but are a little lighter.
The best part, the price is the same 37.95
Randy
www.dougrippie.com
763-477-9272
Randy
www.dougrippie.com
763-477-9272
Randy
www.dougrippie.com
763-477-9272
Randy
www.dougrippie.com
763-477-9272
I heard also that Delrin does make noise, but is that not necessarily the case? My poly on my C5 made plently of noise.
Former Vendor
Delrin when it comes to moving suspension has the potential of making a ton of noise. Without proper lube they will drive you right out of the car. My old ice racer had two large delrin bushings, that I couldn't keep enough lube in because of the conditions. All I would hear at 8200 rpm, 20 some pounds of boost, anti lag popping, open exhaust and all I could hear was those damn bushings.
But when either properly lubed and/or a bushing that doesn't move around (steering rack), Delrin can be a great option. When it comes to control arms, Mono-ball style suspensions rule.
Randy
Randy
I actually had that shift **** on my C5. How is the durability? I took my shift **** off a couple times while doing work on my C5 and the second time, I just about stripped it putting it back on. It did not seem extremely durable for use as part of something with constant motion. Which of the two will last longer?
Randy
www.dougrippie.com
763-477-9272
Randy
www.dougrippie.com
763-477-9272
Former Vendor
Former Vendor
Randy
Former Vendor
http://en.wikipedia.org/wiki/Acetal_resin
http://www2.dupont.com/Plastics/en_U...in/Delrin.html
Is this what you meant
Randy
Randy
Randy
Randy
