Needs ideas for exhaust hangers
Old 11-01-2008, 02:47 PM
Oyishdog
Oyishdog's Avatar
Default Needs ideas for exhaust hangers
I need to see some ideas for the rear exhaust hangers for straight pipes (t1 exhaust). My exhaust has been problematic and is currently not attached in the rear.
Post some pics if you have them please.
Old 11-01-2008, 02:53 PM
MySR71
MySR71's Avatar
Check out the pics here:
http://www.corvettefever.com/howto/73978/index.html
specifically, the 4th picture from the bottom (3 above the dyno plot). This is how Corsa did it for their C5 titanium exhaust system when mufflers were not used. It uses the stock hanger locations with a cross member and then supports which reach down from the cross member. The pipes were then clamped to the supports.
...wait a minute... are you talking for a C5?
Old 11-01-2008, 03:00 PM
Oyishdog
Oyishdog's Avatar
Yes, c5...forgot that part
To Needs ideas for exhaust hangers
Quick Reply: Needs ideas for exhaust hangers
