M1 Brings back Racing oils
http://www.mobiloil.com/USA-English/...cing_Oils.aspx
Mobil 1 Racing oils are designed to maximize performance on the track. Available in 0W-20 and 0W-30 viscosities, these oils are engineered to deliver outstanding power output while providing boosted levels of anti-wear to protect in a wide range of racing engine applications, including highly loaded flat tappet designs.
0-w20 for qualifying
0-w30 for racing
0-w30 for racing
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
Probably will kill the cats with all that zinc. But, considering the only Mobil 1 for street use with any appreciable amount of zinc left in it is the 15-50, I suppose one might add 'jes a leedle' from the new racing formula to get good protection at the track.
Standard M1 oils pulled most of the Zinc and other max wear additives out some time back due to EPA regulations. They are still good , but this blend will be a bunch better for the track. If you have a tight strong engine, how are they going to cause problems with the cats ??
Isn't it actually the phosphorus in the "zinc" that harms the emissions system?
Also, which is better:
1. Low viscosity oil that circulates with less pressure but more volume?
OR
2. High viscosity oil that circulates with more pressure but less volume?
OR
"I've been using Mobil 1 15W-50 in my race car. How are these new oils better/different?
Mobil 1 15W-50 is a higher viscosity oil that delivers a thick oil film for protection of high performance engines. While Mobil 1 15W-50 can be used and is recommended for both street and track use, the new Mobil 1 Racing oils are only recommended for use in race engines at the track. Mobil 1 Racing 0W-30 and 0W-20 are lower viscosity oils designed to increase power output versus higher viscosity oils. Most importantly, Mobil 1 Racing oils are formulated with anti-wear (Zinc/Phosphorus) chemistries at twice the level of automotive street oils to protect race engines including high loaded flat tappet designs used in the NASCAR series."
and
"You say the new Mobil 1 Racing oils are not for street use. Why is that? Does that mean I can't use these oils if my race car is also my daily driver?
Automotive street use oils that meet the latest industry standards are required to have a lower level of Zinc and Phosphorus anti-wear chemistries than oils formulated years ago. The latest automotive street use engine oils are designed to be compatible with emission control equipment. Mobil 1 Racing oils are formulated with anti-wear (Zinc/Phosphorus) chemistries at twice the level of automotive street oils to provide enhanced protection of highly loaded valve train systems found in some race engines. Based on the high level of anti-wear chemistries, Mobil 1 Racing oils are not recommended for street use."
Reading the entire M1 faq, it certainly sounds like these oils are ONLY for use in actual racing engines, not in our street engines when we are doing HPDE. It sounds more like they are recommending using the 15W-50 for street cars that are running on the track.
Does anyone have any further info on this? It also sounds like these oils won't even be available until next spring 2009.
If you do a search on this forum for "oil for flat tappet engines", you will find over 251 threads. Many have great information, results of lab tests from a variety of users. If you visit other forums you will also find a lot of good information on the oils that have the amount of zinc and phosphous necessary to protect flat tappet engines. If you have a roller cam engine, you have no problem with today's oils.
With so much information, you will also find those that have used a specific brand of oil for 20-25 years with success. However those oil formulations changed due to enviromental law and the necessay levels of zinc and phosphous was removed.
The only oils that will protect your flat tappet engine now are racing and off-road oils. Most of these oils will state on the container that thet have the necessary levels of zinc and phosphous to protect a flat tappet engine. Do not use an oil the has the "sunburst" logo on it, as these oils will not protect your flat tappet engine.
Another choice would be to use HDEO's aka Heavy Duty Engine oils. These are oils that were designed for Heavy duty diesels but also carry a gas motor rating. I ran Rotella Synthetic 5w-40 in my car the one time I took it to Roebling.
That was my guess too. I couldn't find any information. What else is different besides Zn?
Valvoline
Not to HiJack the Mobil 1 thread.... but this is what I found on Valvoline
http://www.valvoline.com/downloads/2008-003a.pdf
As most of you know, Zinc Dialkyl Dithio Phosphate is consumed with metal-to-metal contact in an engine when it forms a hard, protective layer at the area of contact.
Mobil was already pulling zinc (ZDDP) out of their additive package before the tighter EPA regulations (phosphorus levels were more important than zinc levels as was mentioned previously). High M1 film strengths meant there was very little metal-to-metal contact in modern engines under normal operating conditions. ZDDP is only "consumed" when there is metal-to-metal contact and it was not needed at higher levels with the latest additive packages. And, adding more ZDDP did not provide more protection in a healthy engine during normal drain intervals.
Removing ZDDP helped M1 reduce combustion deposits and kept engines cleaner. It also reduced some forms of engine corrosion.
If you are worried about ZDDP levels in a higher stress application (racing or in engines with higher cam and spring loads), simply change your oil more frequently. Oil is inexpensive (considering the cost of racing) and changing it more frequently under high load conditions ensures there is a sufficient level of ZDDP to protect the engine and it won't damage your cats.
Premium Supporting Vendor
Interesting. Wonder if that move was in response to the three new AMSOIL racing oils:
AMSOIL Dominator 5w20 Racing Oil
AMSOIL Dominator 10w30 Racing Oil
AMSOIL Dominator 15w50 Racing Oil
Either way, good to finally have some more high ZDDP options available for track use.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
The real issue is the flat tappet cam, which the vast majority of us on this forum don't have to deal with. The posting about the benefit of using high concentration ZDDP oils in situations where we could experience oil starvation(high G track driving) is very interesting; I have never read that before but it makes sense. FWIW, I have over a hundred track hours of usage on my V710 shod LT1, Gtech readings above 1.25. I have never had any problems and yes I have always used a high concentration ZDDP oil, Redline 10w-40. If anyone is interested, here are the UOA's:
http://www.bobistheoilguy.com/forums...52#Post1306952
There may be a threshold concentration level where ZDDP provides adequate protection against metal to metal contact.
SoCal.
I did replace my cats after 60K after it failed smog. I think you can use RL 10w-40, but it will compromise the life of your cats. I believe the other RL formulations have already lowered their ZDDP and Moly levels.
