Centric C6Z06 rotors, 68 dollars
I just did a search online and found Centric rotors for the C6Z06 for 68 dollars a piece. Can anyone provide feedback
OEM are $120 each, but $68 would be great!
Also, I now have had 2 full seasons on my car (8-10 days per year) and I STILL have the original rear rotors that came with the car, but the fronts have been replaced twice. But not too bad for OEM rotors with holes drilled in them. Amazing they last longer than the solid NAPA's I used for my C5.
I called to confirm the price and it is on the money 68.00 they only have centric fronts for the c6z06 but I was told to check in a week for the rears
I just went and looked on their website and those do not appear to be Z06 front rotor sizes.
The C6 Z06 front rotors are 14" diameter, and the rear rotors are 13.4".
The ones on that website say they are Front rotors for BOTH the "6 Liter Base" and the "7 Liter Z06". Obviously that can't be. They say the $68 rotors are 13.39" diameter. That's not a size for the front rotor for either the C6 or the C6 Z06. It sounds like it is the size for the Z06 rear rotor, but if it's not specifically designed for the rear (with the drum for the e-brake) then it won't work.
So.....I wouldn't get too excited about being able to get 68 buck rotors for your Z.
Bob
Bob
Found the Brembos for $120 for "Heavy Duty Brakes".
http://www.autopartswarehouse.com/de...3-1775085.html
And more Brembos for $109 for "Standard Brakes".
http://www.autopartswarehouse.com/de...3-1687394.html
Couldn't find any link for the Centrics. Just have to call i guess
Is it me or do the Brembo prices seem...welll.....to good to be true?
That is a BASE C6 rotor, not a Z06 size.
I didn't bother checking the second link.
This website doesn't seem to know what size rotors are required for a C6 Z06!!!
Bob
Bob
Bob
Location: If you don't weigh in you don't wrestle Road America
Check out rockauto, I looked up for a Z06 and they have both listed, the correct Centric's part number for the Z06 front is 120.62102.
They have the O.D. listed at 355mm (14"), but they are priced at $100, not quite the $68, they had some listed at $71 but they were the 13.4" which they did say were for the Z51, not sure why they would even have that listed on a page for Z06 parts...
Hope this helps.
Just a little side note on the Centric rotors, they are the parent company to StopTech and make the factory rotors for Toyota trucks, if they use the same metallurgy as the truck rotors they should be a fairly high quality rotor, just something to think about.
I'd be interested in any feedback that you guys come up with on these.
Oh you should be able to get the Centric rotors from any StopTech dealer if that helps you track them down.
Hope this helps.
