FS: Traqmate Complete / TraqData Module
$850 FIRM. (New is $1000). Includes TraqPaq battery power source as well as hardwired power connections. Everything you need: Display, Sensor unit, GPS antenna. Will throw in the Display mounting bracket free.
Also have the TraqData module: $100 (New is $130)
"TraqData allows you to hook up 4 analogs operating on 5, 10, or 20 volt ranges, 2 digitals, and a tach signal input to your Traqmate. This device will work with vehicles using a traditional coil or having a 12V ECU signal, 12V Fuel injector pulse, or 12V Coil-on-plug firing signal. It will also work with a 5V ECU or Tach signal. "
Why are you selling it ? With the traq data module do I need to buy sensors also ? What are the 4 inputs you can hook up and how would you do it ? Do you also have a traq sync and/or traq studio ?
THANKS, RAY
THANKS, RAY
Depends on what data you are trying to pull. If youre trying to get something like a TPS, you can tap into the signal. You set the voltages up for the range of values for 0% - 100% throttle, etc. Im sure some of the other guys on here have done similar.
On my car, all I did was hook in A/F and RPM. You can hook whatever inputs you want into it. Ive seen people hook in brake on/off, TPS, Water temps, A/F... I do not have TraqSync or TraqStudio.
Ive used it to mainly log laptimes, qualifying times (it actually has a qualify feature to tell you if your current pace is slower or faster than your best lap), and to analyze segments.
Im selling because I am buying an Aim Pista.
You can use it to do nifty distance vs. velocity graphs also. And compare between cars. Here is one of my car vs. a Spec3:
http://brakeswapracing.com/ericwong/...pec3vsGTS3.jpg
Here is another at Summit Point. You can tell where I get on the brakes later, as earlier, etc etc
http://brakeswapracing.com/ericwong/...te/BoxWong.jpg
Here is a brake/turn map for Summit:
http://brakeswapracing.com/ericwong/...Pbraketurn.jpg
Brake/Turn map for NJMP:
http://brakeswapracing.com/ericwong/.../braketurn.jpg
Friction Circle Graph of Summit:
http://brakeswapracing.com/ericwong/...tioncircle.jpg
