[FS] Drivetrain from 96 Track Car
Moving on to other interests!
I see a lot of nice track rats for sale, so I thought I would offer up some proven assemblies for someone looking to add a little performance to their current ride.
"SOLD"
Carbed & Stroked LT-4
(478.5 dyno HP @5900 rpm) Aug 07 on eng dyno after rebuild
(413.7 RWHP @5900 rpm) Dec 07 on chassie dyno after 30 laps at CMP
Rebuilt by Abacus Racing in VA Beach, VA. Completed Aug 07 and has just a handful of NCCC/Time Trial laps at CMP, Roebling, and Jefferson circuit at Summit Point. Plus approx. 60 autocross runs.
LT block with Eagle 383 rotating assembly
Fidanza aluminum flywheel
Titan GM Sportsman oil pump
LT-4 heads, ported and decked
1:6 roller rockers
Cam specs
...Duration@ .050: Int.-242 Ex.-248.
...Lift: Int.-.586 Ex.-.581.
...Max head flow: Int.-278 cfm Ex.-187 cfm
GM LT-4 4 barrel intake #24502592
Quick Fuel- Wedge Float road race carburator #Q-750-CT
AED billet aluminum throttle bracket #6600R
Lokar throttle cable #TC1000HT36
Mallory fuel pressure regulator #4309
Dual feed braided fuel line with 0-15 psi gauge
K&N X-Stream air filter assembly
GM water pump #EWP18-1119
MSD ignition box. Digital 6 plus #6520
MSD crank trigger
MSD Blaster 3 coil
MSD distributor #8489
Taylor plug wires
Alt/PS pump/Starter
Stainless long tube offroad headers with sensor bungs
3 inch exhaust with a Dr Gas X-pipe and Flowmaster mufflers #943040
AC delete bracket and pulley
Oil vapor catch can
AUTOGAGE tach with shift light
Phantom series gauges by Auto Meter-Oil press, Oil temp, Water temp,Volts,Fuel
The whole package listed above, ready to bolt in and fire it up! $7500.00 or I will sell any piece seperatly.
ZF Blue Tag Transmission- rebuilt by the ZF Doc
Stock magnesium bell housing with clutch fork
Master and Slave cylinder
Short throw shifter with delrin ****
Stage 3 clutch and pressure plate from Carolina Clutch (what’s left of it)
$1400 or I will sell any piece seperatly.
Dana 44 rear with 3.73 gear (hub to hub)
Vette Brakes HD camber rods with spherical rod ends
Vette Brakes composite spring
20mm sway bar with poly bushings
Vette Brakes HD toe rods with spherical rod ends
Vette Brakes HD 4-link(dog bones) with spherical rod ends
Half shafts/drive shaft/C-Beam
Shocks/Hubs/Knuckles
Stock 96 caliper/NAPA rotors/Hawk pads
Braided lines
$1800.00 or I will sell any piece seperatly.
THANKS FOR LOOKING!!!
Jeff
"SOLD"
1:6 roller rockers
Cam specs
MSD crank trigger
MSD Blaster 3 coil
Taylor plug wires
Alt/PS pump/Starter
Oil vapor catch can
Braided lines
Jeff
This is a very good car and would hate to see it parted out. If someone wants a fast,reliable C4 car, this is the one to get.
Jeff never took any short cuts on this car and everything is done RIGHT! If I had the extra $ I would buy it in a minute.
Good luck with the sale!
Aaron
Aaron
St. Jude Donor '06
that was my idea! had to go under the alternator bracket with the tall covers... nice car ,,,and extreemly well cared for...
Johnny
life is good!
Johnny
life is good!
If you wind up parting the car, (shame if that happened), how much for the ground effects?
The packages for the body will break down something like this.
1) Front bumper with lighting, rear bumper with lighting, and all skirting
2) Hood with scoop and vents
3) Head light assemblies
4) Windshield fairing with winglets for targ top
Someone has already expressed interest these
5) Doors with glass
6) Targa top
I think I run the same tires and wheels on my '85 as you have. I'm running 315s in the rear and 275 in the front. The guys at Kuhmo want me to go to 315s all the way around.
What are your wheels and tire sizes?
Richard Newton
101 Projects for Your Corvette 1984-1996
Richard Newton
Richard Newton
Richard Newton
The rear fenders and hood wheelwells have been slightly flared. The flaring is most visible in my sig picture below.
As of 12-23-08... I'll sell any part you need!
