Autocross alignments are good for normal fast roads etc :)
St. Jude Donor '03 & '05
Autocross alignments are NOT good for normal fast roads etc :)
My corvette, 93 type, with an autocross aggressive alignment doesnt do well on high speed breaking and cornering here in Hawaii on the twistys.
Just my observation
Just my observation
The back end likes to get twitchy at the point of high speed braking (45-60mph) and then trying to turn, is this normal for an autocross alignement at higher speeds than at low speeds such as tight autocross, 15-30 mph?
My aligment is -2.2 front with 1/16 toe out and -1.7 rear camber with 1/16 toe in.
It's possible that your rear toe-in, changes to toe-out under heavy braking which will make car unstable. Maybe you need more static toe in to prevent this from happening.
Received 8,928 Likes
My C5 Z starting doing that at the end of the season. The problem turned out to be both rear tie rods. Each had about an 1/8 in play when measured at the rim. Nothing like the rear toe changing while you are braking or cornering.
Bill
Bill
I can neither confrim nor deny the fact its been like this for a while, but I just started really noticeing it as I am autocrossing and practing more , yet at higher speeds.
Usually I dont run roads fast here.
140000 miles on rear toe rods.
