If you use T1 or other adj. sway bar links - help
Old 11-28-2008, 04:53 PM
froggy47
froggy47's Avatar
Default If you use T1 or other adj. sway bar links - help
Are these on right? Large sleeve makes the space for the bar to clear during movement, short sleeve on the nut side of the bolt/nut.
Correct?
What about the nuts? To the back of the car (like I have them) or does not matter?
I know I did not tighten the lock nut yet.
Thanks!
Old 11-28-2008, 06:20 PM
1ED1
1ED1's Avatar
the sleeve will eat into the a arm you need a washer there.
Old 11-28-2008, 07:51 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
the top of the link needs a spacer on each side, or the ball movement is limited by the head of the bolt. The angles look perfect however.
Old 11-28-2008, 08:34 PM
froggy47
froggy47's Avatar
Thanks, will do.
Old 11-28-2008, 08:38 PM
Z06cool
Z06cool's Avatar
Need a sleeve on both sides of the ball joint. From the picture, bottom is correct, top is incorrect.
Old 11-28-2008, 08:39 PM
froggy47
froggy47's Avatar
Thanks, I have no idea why I did the top different from the bottom, I'll change that, I don't think it'll mess up the angles very much.
Maybe that's why they are popping & clunking. I greased the bar & used some washers to "float" the bar (so the bushings don't have such a huge compression on the bar. They are the correct bushings for the bar.
I also greased the heim's & then wrapped some racer tape over them to keep them clean & keep the noise down. Still noisy though.
Old 11-28-2008, 08:45 PM
froggy47
froggy47's Avatar
There is a longer & a shorter sleeve for each heim. When I do the top over, does the long sleeve go next to the bar (the way it is now) and bring the short sleeve to the other side of the heim (where it is missing now) or put the short next to the bar & move the long over?
Old 11-28-2008, 09:59 PM
speedyc5
speedyc5's Avatar
As David said the angles look good. I would leave the long spacer where it is.
Old 11-28-2008, 11:26 PM
froggy47
froggy47's Avatar
Thanks,
You guys are the best.
To If you use T1 or other adj. sway bar links - help
Quick Reply: If you use T1 or other adj. sway bar links - help
