Tires????
Old 11-30-2008, 06:55 PM
F.J.B.
F.J.B.'s Avatar
Location: Vette Doctors Performance RX450 - 466RWHP !!!
Default Tires????
Been using Nitto R2s for the past two years. Quite happy with them.
But its time to replace them for the upcoming season.
Is there something "better" out there?
Old 11-30-2008, 08:12 PM
rustyguns
rustyguns's Avatar
not really... nitto R2's are excellent....i like Kumho V710's too
Old 11-30-2008, 08:20 PM
63Corvette
63Corvette's Avatar
Hoosier A6. If it's good enough for Danny Popp, then it's good enough for me.
Old 11-30-2008, 08:32 PM
LehmanZ06
LehmanZ06's Avatar
HOOSIER Daddy ?
Old 11-30-2008, 09:14 PM
gkmccready
gkmccready's Avatar
"Better" in what sense? If you use the Nittos because you drive them to/from the track and you still want a DOT-R tire then you're pretty limited in choices -- Nitto & Toyo. If you trailer to the track and want track tires, then the options open up a tonne...
Old 12-01-2008, 12:30 AM
F.J.B.
F.J.B.'s Avatar
Mostly like them cause they "stick" like glue and allow me to drive them to and from the track.
Old 12-01-2008, 01:04 AM
gkmccready
gkmccready's Avatar
If you're looking for streetable rubber, you're looking at the Nitto R2s, Toyo RA1s, Toyo R888s, and maybe Nitto NT01s? While these tires are way better than street tires, there's another step or three before you get to "stick like glue" (Hoosier A6). :-)
Old 12-01-2008, 12:40 PM
F.J.B.
F.J.B.'s Avatar
Streetable in the sense that I drive to the track 9 out of 10 times. So I need a tire that may encounter adverse weather conditions.
And yes, my Nitto R2s stick like glue on the track. Hoosiers I think would be a little drastic for my needs.
Old 12-01-2008, 12:51 PM
waktasz
waktasz's Avatar
Hoosiers are not drag racing tires. Sure they are sticky and will work but that's not what they are made for. And you can't drive to events on them.
Old 12-01-2008, 02:44 PM
fire_n_ice
fire_n_ice's Avatar
Anybody know if the Nittos come in stock C6 Z06 sizes? I'm guessing no...
Old 12-01-2008, 02:53 PM
MungoZ06
MungoZ06's Avatar
St. Jude Donor '10-'11
Nitto NT01's or 555RII's do not come in C6Z06 sizes ...
Don't know anything more aggressive one could mount and drive to/from the track ... only possibility being Pilot Sport Cup's at 80 UTQG instead of the 100 on the Nitto's and Toyo's.
To Tires????
Quick Reply: Tires????
