Traqmate voltage settings
Old 12-08-2008, 08:00 PM
Racer Buzz
Racer Buzz's Avatar
Default Traqmate voltage settings
Anybody out there care to share what they are using for the hi-low voltage settings vs the hi-low temp settings for a Traqmate data acquisition unit in a C5 with the stock GM oil temp & water temp senders? Also what voltage settings with an LS-7 90mm T/B?
I would appreciate the help.
BUZZ
Old 12-08-2008, 08:11 PM
Dreamin
Dreamin's Avatar
PM '2002rich' for Oil temp voltages. Not sure about Water temps.
Quick Reply: Traqmate voltage settings
