*** MTI Racing & Pfadt = BIG 11-day sale ***
Old 12-12-2008, 03:51 PM
0MTI RACING
Former Vendor
MTI RACING's Avatar
Default *** MTI Racing & Pfadt = BIG 11-day sale ***
MTI Racing and Pfadt Racing are offering 10% OFF COILOVERS and POLY BUSHING KIT for the next 11 days!!!
The sale starts RIGHT NOW! (Friday 12/12 @11 am EST)
Sale ends in 11 days (12/24 11am EST)
C5 & C6 Pfadt Coilovers (reg. $1890) Sale = $1701
C5 & C6 Pfadt Control Arm Bushing Kit - Poly/Aluminum Sleeves (reg. $290) Sale = $261
C6 Z06 Pfadt Coilovers (reg. $1890) Sale = $1701
C6 Z06 Pfadt Control Arm Bushing Kit - Poly/Aluminum Sleeves (reg. $399) Sale = $359
We anticipate to have everything in stock.
Call or email Jason ( jc.mtiracing@yahoo.com ) or Stephen ( ss.mtiracing@yahoo.com ) to order a set. Due to the amount of phone activity on this sale we will do our best to ship same day.
Need them installed?
If you are within 250 miles of GA, please PM or call me to discuss a special install price for you.
Thank you,
Stephen
MTI Racing
(770) 919-7774
www.mtiracing.com
** COILOVERS **
C5 & C6 POLY BUSHING KIT & SLEEVES
C6 Z06 POLY BUSHING KIT & SLEEVES
COILOVERS:
Pfadt Racing brings you one-of-a kind adjustability and performance with our Coil Over Kit. This kit was engineered with the performance street driver and road course racer in mind. As an engineering firm, we don’t believe that an off-the-shelf shock body is the appropriate solution for your Corvette.
Some will tell you that if you’ve got 16 positions of damping adjustment, 15 of them will be wrong. We would argue that for 16 cars you need 16 unique settings, not to mention the needs of dual-purpose (street and track) cars. Our single damping adjuster controls both compression and rebound. The range of adjustment provides a wide choice of damping to accommodate both daily drivers and dedicated track cars. For example, most people like to drive to and from work with our coils set around 8, while for track days they’ll increase the damping to 12.
If the adjustability intimidates you it’s only because it’s something new for you – not because it’s actually hard to do. Moreover, if you don’t want to adjust them, you don’t have to. We supply recommended starting points that offer a well balanced, well engineered setup that we actually run on our own cars. It’s the best of both worlds. If you choose a product that doesn’t offer adjustable damping, your only option for setting up your car will be to change the springs. And if you change the springs without the ability to adjust the damping accordingly, you’ve just ruined the “perfectly balanced system” that you thought you bought. Pfadt, along with manufacturers like Moton and Penske all understand the necessity of adjusting the damping to perfect the handing.
One of the key advantages of our coil over kit is the flexibility with setting ride height. Our shock bodies are fully threaded and thread into (or out of) the lower mounting cup giving you the ability to adjust the overall shock length by about 3 inches. It’s no problem to maintain stock ride height or slam it nice and low. The important thing about changing ride height by using our threaded body is that you don’t have to sacrifice shock travel to lower the car.
Compared to the stock C6 Z06 leaf springs, our coil overs are approximately 50% stiffer. Pfadt brand components are strong, lightweight and tested for dependability and durability. Our mounting cups are custom designed brushed aluminum for functionality and elite appearance. Our Pfadt coil springs are engineered, built, and tested not to take a set.
The installation is straightforward and does not require any modifications to the chassis. These coil overs will bolt right on. You just need to remove the leaf spring.
The Pfadt Coil Over kit will save you over 3 pounds over the stock leaf/shock package.
All Pfadt Coil Overs are now shipping with our new aluminum-delrin split spherical upper mounts! Our new mount removes several inches of wasted space in comparison to a clevis style mount. This allows maximum ride height flexibility and shock travel in the tight packaging space of a Corvette. Our mount does not consume valuable shock length and travel like a clevis style mount.
POLY BUSHING KIT:
If your car still has the factory rubber bushings, you’re losing valuable control due to the flex of the soft rubber bushings installed at the factory. Our poly kit will make your car respond to turns like the super car that it is! The factory bushings are known to deflect more than a ¼ inch in turns which equates to almost 1 degree of lost camber. With our poly bushings that deflection is gone and you’ll make the most of your alignment.
Our poly bushings are graphite impregnated for long life and low friction. They are engineered with special grooves to maintain lubricant on the bearing surface, keeping the noise away. We include lots of lube specific to our polyurethane. In addition, we’ve engineered custom aluminum sleeves for light weight, low friction operation. The front upper pivots are machined with an offset to offer maximum camber adjustment.
Unlike most kits available, the Pfadt kit also includes the lower rear shock mounts, setting it apart from the competition.
Old 12-15-2008, 09:36 AM
0MTI RACING
Former Vendor
MTI RACING's Avatar
8 Days Left!
Old 12-15-2008, 07:59 PM
Oyishdog
Oyishdog's Avatar
Are you selling the new mount system for the coilovers or the older style?
Old 12-16-2008, 11:30 AM
0MTI RACING
Former Vendor
MTI RACING's Avatar
Default New style mount
All Pfadt Coil Overs are now shipping with the new aluminum-delrin split spherical upper mounts.
Old 12-16-2008, 12:16 PM
Oyishdog
Oyishdog's Avatar
cool........very tempting...
Old 12-17-2008, 09:37 AM
0MTI RACING
Former Vendor
MTI RACING's Avatar
Default 6 days left
6 Days Left.
Still enough time to ship for Christmas, so you can install between Christmas to New Year.
Old 12-22-2008, 09:34 AM
0MTI RACING
Former Vendor
MTI RACING's Avatar
2 days Left!
Your car wants coilovers.
Place your order now before the special runs out.
To *** MTI Racing & Pfadt = BIG 11-day sale ***
Quick Reply: *** MTI Racing & Pfadt = BIG 11-day sale ***
