Rear 305's rubbing in inner fender - Pics
Old 12-14-2008, 07:17 PM
sperkins
sperkins's Avatar
Default Rear 305's rubbing in inner fender - Pics
So what's the deal here? I hear about guys running 315's all the time, but look what I found after running at Road Atlanta last weekend. I'm running 305/30/18 V710's on stock speedlines and stock suspension on my 2003 ZO6. It only happened on the drivers side so obviously the left side of the car was loaded more than the right. Has anyone seen this happen before?
Old 12-14-2008, 07:25 PM
wallyman424
wallyman424's Avatar
i cut mine out
just let it happen, its no big deal. when i bought my car, the inner fenders were actually worn all the way through. no biggy.
Old 12-14-2008, 09:39 PM
rasrboy
rasrboy's Avatar
Originally Posted by wallyman424
i cut mine out
with Wally, You don't want me to post pictures of my wheel wells or whats left of them.
Shake and bake baby!
Aaron
Old 12-14-2008, 10:35 PM
sperkins
sperkins's Avatar
Damn. I was thinking you guys were going to try and convince me to buy some kind of super high spring rate upgrade. I'm pretty easily persuaded ya know.
Old 12-15-2008, 01:07 AM
rasrboy
rasrboy's Avatar
Nope! I was just gonna tell you to strap in some sand bags in the passenger seat to balance you out.
Old 12-15-2008, 01:13 AM
sperkins
sperkins's Avatar
You aint right.
Old 12-15-2008, 06:08 AM
97coupechuck
97coupechuck's Avatar
looks normal to me! Run em' and before you have probs with sides of tires, the tires will be wore out! Go on a diet!! LOL, sand bag to even weight? sure, why not!
Old 12-15-2008, 06:07 PM
autoxer6
autoxer6's Avatar
It seems like the assembly fixture was off a little bit on the C5 Z06. The rear subframe is a little bit to the right on most cars. You can raise the car on the frame, loosen the 4 big nuts holding the sub frame on, then pry it over while someone tightens the nuts down. Some autoxers want every last bit of camber so they do this to even out the max camber on both sides. You just have to get an alignment after. I gained .1 or .2 degrees of camber.
Old 12-15-2008, 06:42 PM
AU N EGL
AU N EGL's Avatar
my 335s USE TO RUB. Dont any more
and What Inner Liner of the Wheel wells? Did vetts come with those?
Old 12-15-2008, 07:10 PM
R Mackow
R Mackow's Avatar
My A3SO4s did rub w/1 deg. neg camber, on stock C5 wheels. Used 1/8" fabricated aluminum wheel spacer which still allows hub to engage wheels. i have one spacer left(not sure what happened to the other.)
Now I run 315s on 17" ZR1 wheels all around and do not experience rubbing.
Old 12-15-2008, 09:02 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Stock ride height?
Old 12-15-2008, 10:43 PM
sperkins
sperkins's Avatar
Originally Posted by Jason
Stock ride height?
Yep.
What's odd is that I ran just as hard and just as fast at the same track this summer on a set of 305/35/18's and I didn't have this problem. The 30 series tires I used last weekend are smaller in diameter so I can't understand why it's happening now.
Old 12-15-2008, 11:33 PM
spazegun2213
spazegun2213's Avatar
haha, my car was mini tubed... i guess there is a good reason for it
Old 12-16-2008, 07:30 PM
gmccreary
gmccreary's Avatar
Scott,
Please let me know about future events. I'm deployed right now but should be back in mid-February.
Greg
Old 12-16-2008, 08:10 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
just remove the liners when they disentigrate. As long as they aren't eating to the inner tub (the fiberglass part BEHIND the plastic liner), no harm is being done.
Old 12-16-2008, 09:03 PM
sperkins
sperkins's Avatar
Originally Posted by gmccreary
Scott,
Greg
Hey Greg. Good to hear from you again. I'm registered with NASA to run again at CMP in Feb. I ran with NASA the last half of 2008 and loved every minute of it. We ran at Road Atlanta a couple of weekends ago and had a blast. Next event there is March 14-15. You should check them out:
Confirmed upcoming events at a discounted rate:
http://www.nasaforums.com/viewtopic.php?f=42&t=25218
Thanks again for your service!
To Rear 305's rubbing in inner fender - Pics
Quick Reply: Rear 305's rubbing in inner fender - Pics
