Homestead Hooked Jan 3, who's going?
Old 12-22-2008, 03:59 PM
urslooow
urslooow's Avatar
Default Homestead Hooked Jan 3, who's going?
There is a very lightly registered HPDE day at Homestead being put on by Hooked on driving. you get 5, 25 min sessions very un crowded. come on and sign up. Novice spots still open! just go to www.hookedondriving.com
Old 12-22-2008, 04:57 PM
rfn026
rfn026's Avatar
The problem may be that they're competing with Chin Motorsports. Chin has a Jan 3 event at Sebring.
Richard Newton
Corvette Race Car Blog
Old 12-22-2008, 07:20 PM
Mjolitor 68
Mjolitor 68's Avatar
I signed up for Homestead Jan 3, going to try out my new Carbotech pads
will do Jan 10 & 11 at Homestead
Sebring is too far from Miami and too rough on cars
Old 12-22-2008, 10:51 PM
urslooow
urslooow's Avatar
Sebring is fun, but when there is a Homestead day it is just so much closer for me. Also the hooked events have soooo fewer drivers in each group---I get a much better experience
Old 12-23-2008, 04:39 PM
klasik-69
klasik-69's Avatar
Hey Steve. Does the event being in Homestead mean you won't be using the trailer ? I hope you put some wheel stops on that thing, you drove Ron and I crazy at Daytona with "the tire goes to the intersection of the tape" alignment. Also, I think the wheelbase of the viper and Z06 are close enough to work for both cars. Speaking of the viper, are you running it at Sebring ?
Mike
Old 12-23-2008, 07:21 PM
urslooow
urslooow's Avatar
Rest assured you won't have to help me I'll be driving it there. I'm still gonna use the Mich cups they have one or two days left. Dudes it was only the 3rd time I used the trailer! R U dudes coming?
Old 12-23-2008, 07:44 PM
B/Stock
B/Stock's Avatar
I've never been to one of these events & was wondering if you guys could answer some questions. How tough are they on the inspections? I have some track wheels/tires that have little tread left. On the website they say you need 50% tread. Do you recommend a instructor for the first time and if so, how much are they? Any first timer tips? Thanks
Old 12-23-2008, 08:08 PM
Mjolitor 68
instructors are usually included in the track fee
As a newbie you need to have a fire extunguisher mounted in the car
have the brake fluid changed, check tire pressures
try and find a track map and look it over for a few days before hand
Old 12-23-2008, 08:12 PM
mcar00
mcar00's Avatar
Fire extinguisher?
Old 12-23-2008, 08:26 PM
B/Stock
B/Stock's Avatar
Originally Posted by mcar00
Fire extinguisher?
Hmm, fire extinguisher. Any advice on where to buy & where to mount?
Old 12-23-2008, 09:36 PM
sgsvette
sgsvette's Avatar
Fire extinguisher?
Guys we haven't required a fire extinguisher in Florida, so you can run without one. We are pretty flexible and try to accommodate everyone.
We don't charge extra for instructors riding with you, and lunch is included in the entry fee.
Looks like the 3 run groups will be around 12 cars per session, so it won't be crowded at all.
Instructors have no entry fee, and we could use some more as some of our regular instructors are away for the holidays.
Old 12-23-2008, 10:35 PM
05C6GAC
05C6GAC's Avatar
Are you doing the Driving Experience school also that weekend or just the HPDE.
Old 12-24-2008, 06:27 AM
sgsvette
sgsvette's Avatar
We are doing a school track day with HOD, meaning the person uses one of our Corvette's and has a private instructor with him all day.
Old 12-24-2008, 06:58 AM
rfn026
rfn026's Avatar
Fire extinguishers are bad news inside a track car. I've seen two people killed when the bottle broke lose. I sure as h*ll don't need one flying around the interior of the car if I hit something.
If your car catches fires just pull over and get the h*ll out. You have never been trained in fire fighting and you could make the situation worse. Let the sucker burn to the ground rather than risk injury trying to put out a fire.
Richard
Old 12-24-2008, 07:08 AM
klasik-69
klasik-69's Avatar
I'm not, trying to set up the car with the new seat and harness bar. Still waiting for the bar.
That's the advantage of the sport cups, although I know some people who drive on the roads (short distance) to the track on Hoosiers. Risky if rain hits. By the way, I know the tire guy told you not to worry about heat cycling the new Hoosiers but I would highly recommend it, it will extend the tire's useful life. Its actually simple...........heat them up then let them cool for about 24 hours without weight on them. Tire Rack does it for $15/tire....well worth it. Have fun at Homestead, be safe.
Old 12-24-2008, 08:24 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Just say no, Jeff.
Old 12-24-2008, 08:35 AM
Mjolitor 68
Up in the Northeast extinguishers are required in all the clubs Ive run wit
I had to use mine once when the trans on my Ferrari 512TR blew at Sebring, the case crackes & trans fluid dumped on the exhaust catching fire. I pulled out my extinguisher and saved my car from becoming a crispy critter
I have extinguishers mounted in all my cars, even my DD
I understand there is the possibility that it could come loose, but I've never seen that happen
To Homestead Hooked Jan 3, who's going?
Old 12-24-2008, 10:11 AM
05C6GAC
05C6GAC's Avatar
Which course are you going to use, the full road course or the modified road course with Nascar turns 3 and 4??
Old 12-24-2008, 10:13 AM
urslooow
urslooow's Avatar
. By the way, I know the tire guy told you not to worry about heat cycling the new Hoosiers but I would highly recommend it, it will extend the tire's useful life. Its actually simple...........heat them up then let them cool for about 24 hours without weight on them. Tire Rack does it for $15/tire....well worth it. Have fun at Homestead, be safe.[/QUOTE]
Actually he said that Hoosier recommends against mechanically heat cycling the tires (check the website) as they do at tire rack. he DID recommend that I heat heat cycle them myself by getting tires up to temperature and then parking it for 24 hrs. How difficult is it to get them up to "temperature" around the neighborhood.? should I get a tire temp gauge (best place to buy online?)?
Old 12-24-2008, 10:20 AM
urslooow
urslooow's Avatar
Full road course not using Nascar 3,4. course is a lot of fun
Quick Reply: Homestead Hooked Jan 3, who's going?
