Question for LS-6 builders/tuners
Old 12-29-2008, 03:49 PM
earthman01
earthman01's Avatar
Default Question for LS-6 builders/tuners
My LS-6 features AFR 205' heads, a G5X3 cam. and LG long tubes. I do 10-12 track events a year. I'm running stock throttle body, manifold, and injectors. Would I benefit from going to larger injectors?? If so what size would be best? Would a ported 90mm TB add any significant power?
Old 12-29-2008, 04:27 PM
J.R.
J.R.'s Avatar
I would think you are putting out close to 440/450 RWHP depending on compression ratio. With stock LS6 (28.8 lb) injectors you are definitely running 100% plus duty cycle at WOT.
I would say 30 lb Ford SVO (comparable to 36 lb. GM) injectors or 39 lb LS3 injectors. 42 lbs would also not be a bad choice.
Some testing from guys on LS1 tech forum indicated a pickup of both mid range and top end with 90mm throttle body and LS6 intake. If you want it ported I would send it to Tony Mamo at AFR.
Old 12-30-2008, 08:43 AM
Independent1
Independent1's Avatar
St. Jude Donor '08
You might benefit by moving up to 36 pound injectors.
Here is a link to a site that explains how to size injectors and provides a worksheet for making calculations. It uses crank HP not rwhp.
http://www.rceng.com/technical.aspx
Old 12-31-2008, 05:36 PM
tjZ06
tjZ06's Avatar
Get some injectors and a good tune before you blow that thing up!
As for the intake/tb, when I got my car it had a ported LS6 mani and ported stock TB. It's a stock displacement build w/ mildly ported heads (not as nice as your AFRs) and a smallish cam (224/230, .591/.591, 113). I did 428RWHP after a good tune. I put a FAST 90mm mani and a 90mm TB on it and picked up 14RWHP (got to 442) but also some torque (I think ~10 at peak) and power was up across the entire pull. Some ppl told me I'd lose low-end torque but I did not.
-TJ
Old 01-01-2009, 01:11 PM
earthman01
earthman01's Avatar
Thanks for the info and the website. I think I will upsize the injectors this winter. My last dyno sheet showed 465 RWHP on Phoenix's Dynotech on a 88 degree day.
Old 01-01-2009, 05:36 PM
GettReal
GettReal's Avatar
I have a very similar set up to yours and I went to 36lb injectors and all is good once again in duty cycle world, just make sure they are flow tested. Fast 92/90 would probably get you another 10rwhp
Old 01-01-2009, 07:01 PM
0Louis @ LG Motorsports
Former Vendor
Louis @ LG Motorsports's Avatar
On a heads/cam car already making 460 wheel hp, I fast 90/90 would net ~ 20hp and 25tq in the midrange, if not more.
To Question for LS-6 builders/tuners
Quick Reply: Question for LS-6 builders/tuners
