C6 Z51 vs. C5 ZO6 comparison question
I posted this on the C5 ZO6 section and they suggested this might be the more apprpriate spot.
I'm considering both of these models as a HPDE/ cruiser car; not a daily driver or a show car. Figure 4-6 DE's a year.
Assuming a 30-50K mileage C5 Z can be had for roughly $25K (or less) and an early CC6 Z51 in the $30K range ( or less), which or these cars makes better sense for the intended use?
Both would seem to have the necessary HP, suspension and brakes to work at a track without a lot of mods. The idea of a newer car with potentially a warranty still in effect makes sense, but I like the idea of a closed car (rather than t-top) at the track
Maybe a better way of putting it would be--putting the purchase price differential aside--which of these cars would fit better with what I'm looking for in a car? Major differences between the two?
Thanks for any help.
I have no personal experience in the C6, but a C5Z is hard to beat in terms of what you are looking for. I doubt that you will find many to disagree. They are near bulletproof and very fast in stock form and as you can see on here there are enough parts out there to take it to any level of performance you want.
Thought I've never driven the C6 Z51 on the track, my vote would be for the C5Z and take the money you'll save and put it into track events.
http://www.youtube.com/user/68ray
I've driven just about every combination of C4, C5 and C6 on track and my suggestion would favor the C5 if cost is a factor. For example, I run a C5 Z51 at DEs and things like rotors and pads are not expensive relative to those of the C6. You can upgrade shocks and sway bars to C6 ones on the C5 as well. The C6 stability program is less intrusive in all settings compared to a C5 though.
If both cars are "Stock"... they are very equal on the track.
That said... replacement parts are "cheaper" for the C5 Z06 and available from suppliers like Napa.
The C6 with the Z51 suspension is very refined... better interior etc.
The C5 Z06 is... NOISY MEAN & NASTY... also a very fun car.
If warranty's an issue... you might want the C6... otherwise drive both and decide.
As for the ability to run 17in or 18in wheels, the cost there is in the wheels. Once you're running the non-drilled, smaller rotors you have the same wheel clearance as the C5s with the brakes. The C6 does like different offset/backspacing, but you'll find many folks running C5Z wheels (especially 4 x C5Z rear).
The C6 non-Z is basically a C5 with an updated motor, slight differences in how the rear spring is mounted. and a bit more refinement in the interior.
The cost arguement is a loser outside of the upfront cost, IMO.
