315x35x18 fit on 18" 9.5 wheel
Will a v710 tire 315x35x18 fit on 18" 9.5 wheel for use in autocross?
email me you thoughts.
Dale
dlangkilde@gmail.com
Dale
Dale
Dale
Hi Dale! The tire will fit, but highly NOT recommended for autox. Kumho and I recommend 18x 10.5. I've mounted them on 18x11 CCWs too and work well, but a little hard to pull the sidewall to the wheel during mounting for TirePros.
Darrell Covert
2008 NASA Az. Region TTS Champion
Darrell Covert
Darrell Covert
It will fit but it is really not recommended. Get some stock Z06 18X10.5 wheels. You can run those all the way around if you like too, but I don't know what series you run in, so the rules could prevent that. Best to check that out first.
Aaron
(Kumho Tire-Motorsports Division)
