Blown Up LSX's-What Oil were You Using?
M1 5-30 when it blew. It was also sc'd with 552 rwhp on stock bottom end. Issue was probably pre iginition related. New motor is still on VR-1 plus bottle of STP additive. That should be enough ZDDP. Don't know what to do about oil after 5k miles is up.
I've been looking into this as well. A friend does an oil analysis after every event. Note, not an oil change but sample sent for analysis. Over the past two years he has tried every "over the counter" synthetic except for Pennzoil Platinum. M1 tested worst of all the brands of oils he tried. Castrol Syntec best for the find it at WalMart brands of oil. If you can get Amsoil that tested better than the Castrol. He runs Motul 300V now and changes when Blackstone tells him to.
All tested in 10/40 weight.
Former Vendor
Has he tried Red Line oils yet???
Randy
Former Vendor
Interesting. There is a few other like me that have became anti Mobil-one. Funny thing is Mobil has great fuel here and Mobile is my only credit card. I would be interested to see the test results, but I understand if he will not share them. Hell he has spent good money on the test, it's his info.
Randy
Randy
My father and I both run Redline. In my Dad's 03 C5Z, which he bought new, he's been using 10/40 RL since the first oil change. It doesn't burn oil and he doesn't get the soot/blow-by on the rear bumper that is seen on many others. This is a car that sees mostly all track use it was on track with just over 500 miles on it.
I run Redline 15/50 in my racecar and I went over 1000 on-track miles prior to oil change. I would have analysis but I didn't have anything to collect a sample.
Of course, I don't know, I am not a chemical engineer nor have I ever seen or examined a blown up LSX; but the development and growth of the Zinc Phosphate film is dependent upon the rubbing of steel(aluminum or any high yield) surfaces. After 10 seconds of rubbing(creating high temperature and pressure) a significant 10 angstrom thick phosphate surface develops, after 30 minutes of rubbing the film increases to 600-800 angstrom film. The flat tappet is a classic example of where a ZDDP film would be created and needed, the roller bearing cam portion of the engine would not need more ZDDP but this protective film will also be created in other rubbing surfaces perhaps the ones that cause a catastrophic blow up in the LSX's. If the engines blow up as a result of a dropped valve or a timing chain or a rod exploding then no amount of ZDDP will prevent it but if the failures are a result of oil starvation leading to excessive localized friction after repeated rubbing....
Which elements were elevated in the "worst" oils?
What does "tested worst" mean? Unless his engine is failing, are there really enough constituents in the oil analysis to determine how the oil is performing? Especially considering all the variables that would exist from event to event (venue, weather, traffic, etc, etc). When the ppm levels are low, these variables and inconsistensies are magnified.
A real expert like Terry Dyson can provide a lot of valuable insight:
http://www.dysonanalysis.com/
Former Vendor
Randy
Premium Supporting Vendor
Not hard to get, ordering info in my sig and it will come to your door.
My opinion on this topic in general is that high ZDDP levels are important to the bearings on our LSx engines on the track.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
I just don't think that, for our LSx engines with stock valvetrains, need high ZDDP oils. Modded track engines obviously have unique requirements, but I understood the OP to be discussing stock engines.
Have a good one,
Mike
Subdriver, I wasn't insinuating that Amsoil is hard to get, I think I've seen it at NAPA here. I'd like to try the Dominator race oils this season so I'll likely be clicking that link in your sig.
Vetteless
St. Jude Donor '09
Mobil 1 10W-30 - only left about 2 qts off-track right-side just before the climbing esses at VIR. Just recently pulled the oil pan off - holy CRAP there were a lot of aluminum frosted flakes in there! Pistons 4-6 are all gone along with associated connecting rods. Longest peice of rod I found is about 3". Pistons 3 and 7 are broken, but not shattered. Block inside looks like a grenade went off in there - which is pretty much what happened.
Now running AMSOIL 20W-50 in the new motor, purchased through Brad (Subdriver).
of the intact pistons & remainders of the tops of the damaged
ones.
Photos of the rod journals, bearings, big ends and little ends would
also be interesting.
Perhaps in a new thread?
