Seat install question for you experts
Old 01-05-2009, 03:21 PM
RedLS1GTO
RedLS1GTO's Avatar
Default Seat install question for you experts
The UPS guy showed up today with 2 new bundles of joy... my new Kirkey seats! When I bought the car from Jeff he said that he had not been using the door bars because they wouldn't fit with his seats. Bad news is that they don't fit with the Kirkeys either. By the looks of it, they won't fit with any race seat with wide shoulders. I love the Kirkey seats so getting rid of them isn't an option. My question is this. Should I just leave the door bars out? I don't plan on running the car anytime in the foreseeable future where they are required. The other option is to cut a small piece out of the bottom of the shoulder of the seat. It only needs another 3/4-1 inch of clearance to fit over the bar with no issues. I'm mounting the seats with 4 point brackets on the bottom and a back support as well. Which of these would be better as far as safety is concerned? I'm attaching some pics so you can hopefully see what I'm talking about. Thanks as always for the advice!
Old 01-05-2009, 03:34 PM
coffey
coffey's Avatar
Notching the seat to fit around the bar is what I have done in the past. Even weld reinforcement around that area if you want to.
Old 01-05-2009, 03:50 PM
gkmccready
gkmccready's Avatar
Bend the seat?
Old 01-05-2009, 03:59 PM
RedLS1GTO
RedLS1GTO's Avatar
I never thought about reinforcing the area. I don't see a problem with that at all, especially since it would be high up and on a non structural part of the seat. Thanks!
Originally Posted by gkmccready
Bend the seat?
I don't know how I could make it fit with a bend, the seat goes perpendicular to the bar. I would basically have to bend the entire shoulder support out of the way.
Old 01-05-2009, 04:26 PM
AU N EGL
AU N EGL's Avatar
Dont use the swing out door bars. Those really do not add any structural safety any way.
For any road circuit events, HPDEs, Track Days, you will need FIA roll bar padding on any part of the roll bar that could come within 6" on body or helmet contact.
Good Luck
To Seat install question for you experts
Quick Reply: Seat install question for you experts
