HPDE Wheel Advice Please
I'm looking for a low cost set of track wheels. I used a Mustang on the track last year and switching to an FRC this year. On the Mustang I used a square set up (17x9) all around, same offset front and rear.
On the FRC I'd like to do the same thing so I can rotate. But while absorbing knowledge from this forum I've learned two things: the stock front and rear offsets are different and the stock rim widths are different front and rear.
Questions:
- Regarding the offsets - can I run the same offset all around? If so, what offset?
- Is there any reason to have a wider rear rim or is having same rim and tire width front and rear ok? On the Mustang I didn't want wider rims/tires on rear for a few reasons, including I didn't need more relative grip on the rear end of a already understeering platform.
- I'd like to get a set of OEM Z06 wheels or other lower cost, light weight, strong rims; but in the for sale section all I see pretty much is sets of 4 (18s and 17s)...if you have a set of low cost 17s all around, what are they and where did you find them?
Thanks much, Brad
Questions:
Thanks much, Brad
St. Jude Donor '07
Factory C5Z came with 2 17" rims and 2 - 18" rims.
Cheap, but not so light - AFS or other replica GS or ZR1 wheels (17 X 11 GS Offset) will fit on all four corners.
Not so cheap, but light - CCW Classics
1 Post
St. Jude Donor '08
One other alternative is to run C5 Z06 rears ( 18 X 10.5) all the way around. Might be able to pick some up in the c5 parts for sale section or there are some vendors that sell them. Don't remember which ones though.
Based on the above responses thus far I've learned:
- I can run the rear Z06 wheels (18x9.5 w/~60mm offset) on all 4 corners. These are relatively light wt and strong but they are 18s = higher tire cost and its hard to find 4 of them. Most people want to sell their stock rims as a set (17 front and 18 rear) together.
- I can run the C4 Grand Sport or ZR1 rear rims on all 4 corners. Very hard to find OEM units it seems. Lots of aftermarket replicas available in 17" with a variety of offsets and widths. They are cheap but also heavy and are they strong enough (these are Chinease rims right?).
Anyone else have some inputs? Other than the guys with the high dollar CCWs, HREs, etc, what are you guys on a budget using?
I'm using 18x9.5 fronts and 18x10.5 rears with 275/35-18 and 305/35-18 tires. My race tires are shaved and slightly used Toyo R888s that I can get for about $75 - $85 a piece. (Send me an email and I'll hook you up with this great deal on tires.)
I recommend you find a set of C5 rear wheels (18x9.5) and a set of C5Z rears (18x10.5). There are people willing to sell them separate. Send an email to someone who is trying to sell a four tire set, but not getting any buyers. They're often willing to separate the set and get half the money, versus keeping the set and getting no money.
Or try http://www.corvette-wheels.com/ for great prices on new reproduction wheels. I got the wheels I'm using from them a few years ago. (This will allow you to get different sizes front & rear or four identical sizes that still look like a matching set.)
Bob
I love my replica a mold wheels for track use. I have 4 17x11 and 2 17x9.5 in the GS offset but I try to run with a square setup. They are made in USA by AFS and weigh 23.3 lbs according to my bathroom scale.
One of my friends who has a 996 Turbo was helping me change wheels at the track one time and commented on how light those wheels are with Hoosiers on them. Plus, with the 17" sizes, you can take advantage of used tires from the T1 guys.
Ive never heard of these wheels breaking due to track use and they fit around my LG GStop brakes.
Forum Sponsor: C119 -> http://www.houseofwheelsonline.com/corvette1.html
I have a set of 4 early C5(fat wheels, 18x9.5) that are powder coated white and have some old V700s/285/30-18, that are barely showing tread. They are autox wheels and have some nicks in them but are solid(no cracks.)
They are made to take a 275, but I have put 295s and 305s on these wheels and run them flat out at Pocono/North Course.
They are taking up space in the shed and you can have them for a small donation or less.
Here's another vote for the square C5Z rear (18X10.5) set up with scrubs. As stated earlier, R888 scrubs can be found for $75.
It may take some time but you can find rear wheels for sale on here. I took the extra time to find the 2001 Alcoa version but in hindsight it would have been easier and cheaper to have gone with Speedline.
Something to think about ---- I purchased 2 rears from one seller and then purchased a complete set from another. I sold the 2 extra front wheels on here in less than a week.
John
John
The responses have been a big help, thanks guys! You've given me some good options. If I can get R888 scrubs for $75, I'm all for the 18" wheels.
These will be track only rims and tires - I'll be getting a trailer for the vette, or sometimes I caravan to the track with a buddy who has a truck and trailer.
I run the C5Z06 18x10.5" rims all around. I've run everything from 275's to 315's on them. They are also nice because they will clear most big-brake kits as well (repros may not, as the spokes are often thicker)
I buy scrubs from Bob Chick here usdrctrs "AT" aol.com
His stock varies, but if your not picky about specific sizes etc, he can usually hook you up. To me, for HPDE, there is no difference between 275-305 etc.....I'll take whatever is in the best shape!
If you want 17" C5Z fronts all around I would buy a regular 17/18 set and offer a trade "my 18s for your 17s". I'll bet you will have no shortage of willing partners. This is what I was going to do but went a different direction due to a cheap co owner.
Just a thought...
Just a thought...
And if you need wheels, I'll sell you an old set of GS offset ones. Light, 2 x 9.5 x 17 and 2 x 11 x 17. 295 Hoosiers fit just right on front, 215 on the back, no spacers required. They served me well for many DEs. Tires included, you will have to get the shipping though. Drop me a PM if interested.
Call John Berget at 262-740-0180. He is a small businessman who goes to the races, takes the slightly used tires (scrubs) from the race teams, and sells them to folks like us. They run around $75 to $85 each.
Just tell John that you've heard he has some scrubs for sale, then he'll probably ask you a couple questions, and you'll end up getting the best sizes for your car.
Yes, John B is good also. I used him years ago, but have bought from Bob the past several years. It has gotten harder to get good scrubs the past few years, as liability seems to have kept suppliers from letting go of them after the races, but I still manage to find some good ones.
