How fireproof are you?
Vetteless
St. Jude Donor '09
I spent yesterday and today pulling interior out of the T1 car. First surprise I had was what a nice job Phoenix did painting the interior - looks purdy!!
Second surprise was that the tub was burned completely through and the carpet padding burnt pretty badly in the back of the car. Now my car had a full hard-mounted fire system in it, but still - I didn't realize just how hot it gets back there. You can't see super clearly in the pictures, but on the drivers-side, all that's left is the filaments - all the resin has burned away. You can see where I swiped three fingers through the dust/residue in the area.
My exhaust is 3" all the way back with no cats or mufflers. So, as I do my winter maintenance stuff, I'm going to put some header-wrap around the exhaust back there as well as up where my toasty toes will be and possibly add an in-tunnel heat blanket as well.
Next time you're under your car - have a look at this area!!
Holy floorpan, Batman!
Carpet from that area (drivers side on right) - looks like it was warm.
Gutted interior shots.
pulled all the interior out of mine this weekend and the carpet pading along the tunnel by my feet was cooked and the original stick down insulating sound matt in the rear had turned to charcoal where yours burned thru. Need to find some good fireproof heat matt to put up in the tunnel. Aaron you are going to be surprised at what you find.
Since I am not going T1 the car is on a major diet.
Vetteless
St. Jude Donor '09
I wish I could've weighed what came out - seems like a lot of stuff.
When I took the carpet out mine last year, I left it in the driver's footwell and on the xmissin tunnel where my right leg rests. I knew how hot it was going to be without it.
What model of Recaro seat is that?
How low can you get it to mount for headroom issues?
Can you adjust the layback angle?
Is it HANS compatible?
Thanks,
Matt
Thanks,
Matt
http://www.pegasusautoracing.com/pro...p?Product=1828
I was thinking about using some of this stuff where things get roasty...
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
I installed the fitted blanket underneath the tunnel (outside). Kinda pricey but does a great job. It was around $250 but after burning the imprint of an allen key I was removing from the console onto my fingertips I thought I would like one. I do like it. But, also, heavy!
You're welcome
All int plastic trim bits (sans door panels, and all speakers), fastners, visors, seatbelts and bolts - 23.10 lb
Driver's carpet - 11.62 lb
Pass carpet - 10.56 lb
Headliner - 2.62 lb
Remaining carpets (rear tub, etc) - 14.95 lb
Owner's manual glovebox kit - 1.18 lb
Passenger floor mat - 1.50 lb
Driver's floor mat - 1.47 lb
Spare Tire kit 5.74 lb
Stock Driver's power seat - 40.96 lb
Passenger manual seat - 30.32 lb
Radio head unit - 4.38 lb
(haven't weighed the radio bezel/center console)
Headliner - 2.62 lb
Vetteless
St. Jude Donor '09
Mark - thanks for the weights! Looks like the stuff I had left in there should be worth close to 90 pounds - sweet!
Arte - yeah, I thought that thing was pretty heavy. Too bad because it seems otherwise like a nice solution. I like the idea of the insulation being outside which keeps the metal inside from getting quite so hot.
Glen - I've been doing a lot of research last couple of days on different options. I think at the moment, I'm leaning towards some of the heavier felt/laminate type stuff in the tunnel, some header-wrap in the back where the body got burnt and also just aft of the manifolds down to the front of the X-pipe (where the cats were) and then add adhesive-backed stuff like you linked inside as needed.
Walead - glad to know I'm not the only one!
Working on getting an aluminum radio bezel/front center column cover made this week where I can mount my Active Handling button - it's kinda fun to get to do a little fabrication on my T1 car!
1 Post
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
The first time I ran my race car at an HPDE I melted my main power cable that ran along the tunnel to the point it started to ground out and fill the car with smoke. Makes me wonder how hard the car was ran before I bought it.
On another note for C6 folks, don't leave anything in your rear storage compartments if you're going to run hard. They get smoking hot since they are literally right beside the exhaust and they're just plastic buckets. I'm waiting for mine to melt...
If heat is a major problem, consider using Koolmat:
http://www.koolmat.com/main.htm
They make a pre-cut kit for C5 Corvettes. I've used their product in several overly hot old cars, including several Jaguar XKEs, and it really is a miracle product. On the E, I used to burn my thigh and the right side of my foot on the transmission tunnel on long trips. Now, with the Koolmat, no more problems at all, and the entire compartment is much cooler. Great stuff. Only drawbacks -- it's not cheap, and it is not lightweight. But it does the job.
The places that get really hot in OEM configuration, above the cats and mufflers, have aluminum heat shields riveted to the tub...and spaced out to give them extra insulation. You always need to be carefull when you modify the exhaust, and wrapping (either the exhaust or the body) is always recommended. Even the cheap, thin reflective tape can make a huge difference in reducing radiant heat transfer
Brake line proximity?
DEI (Design Engineering Inc) and now Thermo-Tec both offer
heat sheath in tubular form with hook-&-loop (Velcro) closures.
DEI's product is called "Heat Shroud" and is available in 3/4 to 1-1/4"
dia sections. Thermo-Tec's version is called "Express Sleeves",
however, Thermo-Tec only offers it in 1-1/2" dia sections.
I use the DEI product to insulate brake lines where they pass close to
heat sources. I didn't expect the hook-&-loop to last but it has -
either it is more durable than expected or there is less heat than I
thought.
thought.
most of the heat is "radiant" heat, not convection or conduction.....so the reflective properties not only protect your brake lines, but the velcro as well. If the velcro was line-of-site with the exhaust, it would quickly melt.
Even cheapo, reflective HVAC tape can offer tons of protection from exhaust heat, as long as there is an air gap between the hot and cool surfaces.
**btw, are the products you mention wide enough to go around ball joints and tie rod ends?????
