Testimonial for DRM radiator
A while back I made a thread here about my overheating problems. I was seeing coolant temps of 260 and oil temps of 300+ and was forced to take cool down laps. I wound up buying the Ron Davis radiator with integrated engine oil cooler as a complete kit from DRM. Yesterday I made it back to the track for the first time since and was shocked at the improvement. My peak coolant temp was 220 and my peak oil temp was 239! Now, there were other factors.
1) prev rad was original w/ 138,000 miles
2) prev coolant was 50/50 dexcool of unknown age (came in car)
Now running 25% dexcool / 75% distilled w/ 2 bottles redline water wetter
3) ambient temps were ~70 yesterday instead of ~80
4) when changing rad I was able to blow more crap out of the AC condensor
But still, holy cow what an inprovement!
And my oil still gets above 170 degrees on the street, it just takes it a while to get there. So thank you to DRM.
For sure i never had that kinda heat at the track with my car before but i too added that rad and it brought the temps down great. Get a heat extractor hood and it will be even better yet. I have one From DRM and it dose a great job
Former Vendor
Thanks for the writeup. It's hard to think about radiators on a freezing cold day here. The bank said -15 degrees, as I drove by 30 minutes ago.
You can install a lower t-stat and turn the fans on a little sooner. For lower water temps.
Randy
Randy
I too am using the Ron Davis setup from DRM with the 25% mixture and water wetter and have been well pleased with it
Hey Randy...ya been doing any ice racing this year??
Here is a question though. With temps getting into the teens this weekend in South Carolina is 25% gonna keep it from freezing up. I think a 50/50 mixture is good to about -30 deg so I think I'm ok but would like a 2nd, 3rd, and 4th opinion before risking it. The car would normally be in a nice warm garage in these conditions but will have to endure the teens at Roebling Road this weekend. I have a nice cover to use but don't think it will be of much good if it gets a little windy
Pat
Pat
Former Vendor
Pat
Pat
We use these antifreeze testers. You suck up some antifreeze-water. If one ball floats it's good to XX degress, if two ***** float it's is good for xx degrees and so on. You should be able to find a gauge down there, and add antifreeze to match the outside temps. You can throw a blanket over it for the night time. It will help retain some heat in the system..
Randy
