Clutch time or not?
Clutch time or not?
Okay, I'm back from another day at the track with another problem so it's time for another tap into the wealth of knowledge in autocross/roadrace section.
We are all well aware of the sticking pedal problem and it just hit me really hard. Right away on lap one of each of my sessions my clutch was gone and I couldn't get fourth gear. I had to slow down, work hard to get it back into third, then run the whole track in third gear. I've run this track many times before and had a half way down pedal a couple times, but nothing like this. After the session, the clutch pedal would either be on the floor, or up but hard as a brick and even when pushed, did not release the clutch. And this is after driving around for 20 minutes without shifting. After the first session, I sucked out the clutch fluid, replaced, pumped clutch pedal, replaced fluid a couple times. Then when I went out, I tried short shifting to fourth. That worked once. Second lap it was completely gone again. Thing is, after I get off track and let it cool for a very short time, it works absolutely perfect for normal street driving. And it is not driving through the clutch. It holds WOT in first and will grab very solid on a 1-2 shift. Also, my clutch fluid is perfectly clear. Is there anything else I should be doing besides changing a clutch that isn't really wore out?
I think what we have is a bad slave cylinder. But I think to get that out you almost take the clutch out anyway. So I'm putting off this expense.
I experienced the stuck clutch pedal syndrome after replacing a perfectly good clutch/hydraulics at 50K mi.
http://forums.corvetteforum.com/auto...-remedies.html
http://forums.corvetteforum.com/auto...dal-redux.html
In addition to replacing the clutch/hydraulics you can heatwrap the hard lines and remove the clutch pedal spring. In my case, I had a C6Z06 clutch/hydraulics installed and heatwrapped the lines, so far I haven't had any more problems.
I'm just thankful I haven't had to deal with this yet. I don't know if I just don't do enough DEs (autox is my primary fun-time), or if I'm not pushing enough power (stock LS-1 with LTs and a tune), or what.
Sorry for the bad news, but try to have a good day anyway!
Mike
8 years old, just like my clutch. With 138,000 miles.
I'm using SRF in the brakes, but still just have cheap DOT 4 in the clutch. That's because since there is soo little exchange of fluid between the resevoir and the slave cylinder, I though the good stuff would never really get down there and all I would be doing is constantly sucking out and throwing away the SRF in the resevoir. Is there a bleeder I can get to under the car and actually flush out the old fluid so the SRF will actually make its way to the slave?
What does changing the slave cylinder involve? Can it be done without removing the entire drivetrain?
you do have to remove the driveline to install the extention... at least all the units I've seen to. same for the slave cylinder.
I think heat warpping the hydraulics has a HUGE impact on how well the clutch pedal feels. There are guys in the drag racing section who get soft clutch pedals after only one or two passes. I have every single line in my clutch system (hydraulic or gravity feed) heat wrapped and I've never experience any type of soft clutch pedal whether it be at the drag strip, on the street or on the road course. I also run Motul RBF 600 and flush it before each event.
