How do you tilt a fixed back seat????
Has anyone seen a way to make a fixed back seat tilt forward? I have the Ultra-shield Pro Road Race seat and want to see if there is a good /safe way to make it tilt forward so I can access the back of the car. this is a street and track car.
To keep it in safely you may not want to do that.
I also have the Ultra Shield Seats, and have them boltd to the floor with the HardBar mounts and a fixted back support to the harness bar.
Seat movement may not be a good idea for safety
I agree it is not ideal but my car is a 68 convertible and I need access to the rear. The battery is back there and so is the storage area. In looking at the NASA rules book I don’t see where it would be illegal. Although the car will be used for HPDEs so some rules don’t apply. BUT I still want to be safe. I see Sparco makes a universal base tilt kit http://www.racer91m.com/servlet/the-...SE-TILT/Detail
But man that looks weak to me!
Who has them? do you have a link? Should have the room. But my seat is mounted very low now (read to the floor). how much higher is this other mount?
I believe the Sparco sliders lock both rails. I think most of the big name seat manufacturers offer appropriate sliders, you'll have to adapter them a bit to hold whatever seat mounts you've got. I figure they're an inch to 1.5" higher than without them.
OT, but Nasa was strict at an event I was at. I have a 6 pt welded in my vert with padding in contact areas... as I pulled up to tech I could see them all thinking, "great, another vert we gotta send home" is your 4 pt welded or bolted?
I have a Sparco Evo in my '72 LT-1 car.....You should move the battery to the well behind the passenger seat for ease of access and better wieght distribution.......
If its a convertible, doesn't the rear tonneau door open giving you free access ???? My car is a coupe with a rollbar and a race seat . Even though I moved the battery to behind the passenger seat, it is still a PITA to get the battery out with the rollbars diagonal and seat belt brace. Its still fits.....barely.
Plus, the C3 is a different animal when it comes to seat position. The seat literally is laying on the floorpan. I installed C5 seats into my '68 and had to fabricate my own brackets. The large diameter steering wheel doesn't help either.
If you are determined to do what you are asking about, then you are definately going to have to fabricate your own brackets or buy a sport type seat that will fold forward instead of tilt. Neither however is good for track use.
As for relocating the battery that is not a bad idea. But I have the same seats on both sides so still no way to get back there.
Going on some old reading the Verts with the hard top mounted are more aerodynamic than the regular hardtop cars. That was why most all the old vintage winning cars were verts with the hard top on. I found that odd but what happens is the reg hardtop has a recessed rear window and that created a vortex and broke up the flow of air in a negative way. This info does not pertain to the late 70s that had the bubble rear window.
