Anyone looking to upgrade to 14" brembos and ARE Stage 3 dry sump cheaply?
I am thinking about converting my Z06 back to stock and selling it. Is anyone interested in trading for stock Z06 brakes or oil system for the ARE Stage 3 and brembo 14" breaks + cash.
For the oiling system I would include all the AN fittings, Pro-Lite hoses etc.
For the brakes I have a brand new set of race brake pads, plus brembo street pads and stainless lines.
If anyone is interested make me an offe
Not sure what I paid. The fittings and hoses were quite a bit alone. However I am pretty flexible on price. Here is a link to the system. Price list is linked below, but I think you may need to price it out seperate.
http://www.drysump.com/kit3.htm
does your car have coil overs? I read in another thread it didnt clear the stock leaf springs?
http://forums.corvetteforum.com/c6-z...by-katech.html
it is mentioned in this thread 5th one down, it later says that a non coil over setup is available, i am not sure what part is changed to make it work with the leaf spring cars, maybe someone else can chime in here
Ya thats the only thing i could have though is the pan doesn't clear the spring. Looks like that could be the problem. However the pan is pretty shallow, so I would really be surprised.
Do you not have coil-overs I take it? Still using stock shocks/springs?
It was in the thread you pasted to me. Its that blue fitting on the bottom of the pan. The oil filter can be mounted anyplace you want. I mounted mine in the driver side inner fender.
let me know if the correct fitting is changed out for non coil over cars and i might be interested, also does yours have that scatter shield installed to keep debris out of bell housing? i think you have a nice lift so atleast is easy to check out
thanks
Derek
thanks
Derek
Don't have a scatter shield, however it would be easy to make something out of aluminum if you are worried about it. As for the fitting, if you are interested let me know what kind of price you had in mind. If it isn't right, I can call ARE and see about getting the correct fitting.
brakes retail for $6995 plus I just paid $600 for another setting of racing pads. The original pads are almost brand new, and so are the racing pads. I was looking to get $4200 + someones z06 brakes.
For the ARE I was looking to get $3500 plus the stock parts from someones car. I have probably $5500 atleast in the ARE setup including all the hoses and fittings, and those are dealer costs.
I have a bunch of other parts I will be selling as well. I thought about selling the entire car for $72k as is, but its probably better to convert it back to stock and then sell the car.
http://www.way2fast.com/carparts.html
Thats a list of parts off the car, their retail cost, and what I would like to get for them. Anyone is interested let me know..
LS7 heads?
Who ported and what were the flow numbers?
Who ported the TB and is it a 90mm ? Any tuning issues??
LS7 intake- who ported ??
Are the front Brembos three piston??
joel
joel
TB is a standard ported z06 tb.
did you sell all your stock parts or something?
that makes it the hardest due to some people keep their stock parts also to return to stock if ya ever sell the car, i learned my lesson after a few heavily modded cars, ya never get the mod $$ back if ya sell it with the car
