Speaking of custom Corvette suspensions
Twin Turbo was a regular in the C3 section for quite some time. He is quite an industrious guy and has a lot of cool ideas. He has been working on his Vette for a while now. It is getting close to a working car...
Uhhhh Houston, we have a problem...
I saw solid shafts AND rigid upper links. Unless there is slop in there somewhere he is going to be putting some serious loads into the U joints...
I know if the links were parallel and all the inboard and all the outboard joints were on the same line (as viewed from the rear), the system would work as a four bar, but that's the only way it is going to not bind up, and a rig like that wouldn't have a good camber curve.
