Opinions on Pilot Cups
I was looking for opinions on the Pilot cups and PS2. I only drive the car on the street to get to the track. But I was wondering if the pilot cups would hold up. Also if anyone has run both if the grip on the cups is that much better than the PS2’s.
Thanks for any info
Thanks for any info
Take a look at this thread over in the C6Z section - it might have some info for ya:
http://forums.corvetteforum.com/c6-z...e-awesome.html
Bob
Bob
St. Jude Donor '05-'08
I had them as rain tires for the track and occasional street use. Actually I used them more on the street since I was lucky it didnt rain that year. I personally think they were the best handling street tires I ever had, but the cost of the tires and the fact that they randomly stop production I decided to go with another tire.
I will go against the other review and say the Hoosiers R6s do out handle them, but not enough for your normal HPDE guy to tell the difference. You should get some decent mileage out of them....
I found them to be crappy track tires, as the tread depth is quite thin on the outside edge, and I almost ruined a set of rear in less than 1 hour of track time at CMP (and this car as lots of rear camber).
I think they'd be good sticky street tires, but not for the track unless you can afford to replace the weekly.
Bob
Bob
I have managed to make F1's last 15 track days
honestly I dont remember, but I never really heard them which might be because I only had them on the street and never really pushed them to the levels I would on the track.
I will ask GeorgeZ to answer your questions. He bought a set of CCWS with MPSC from another ECS customer and I know he used them for a long time on the track before switching to Kumhos I believe (he switched because of price of the MPSC).
The only thing I didn't like about the mpsc's was that after they got hot, they seemed to get greasy. The front would push and the rear would slide in the later sessions. As far as a rain tire, I didn't like them. It was a good tire, lasted pretty long (14-20 track days). They would talk to you on the track well enough. I never ran them on the street, so I can not comment about that, but I ran them until I corded them at pocono.
I run 285/35/18 MPSC's on the front of my 01 Z, I have found that on the front the tire performs well, on the rear the outer edge is a problem. I run a 315/30/18 Nitto NT 01 on the rear and I really like the combo. I know many do not agree with running mixed compounds... I have run many tires and have not come across one that wears with the same consistent performance event after event as long as you can provide at least -2 degrees camber. I have at least 10 events on my MPSC's and I would say they are half life, and I drive to and from the track on the tires.
I know most of you here are talking about "track use", HPDE's , ect..,
But what about "autocross" use for the Pilot Sport Cups ?
Most of my use is on low speed autocrosses, on concrete surfaces, which can wear a set of Hoosier A6's in a weekend or two (2 driver car), the concrete wears them like a cheese grater
Just wondering if I could get double the life with the PSC's vs. Kuhmo V710 or Hoosier A6......or even the Kumho V700
FYI- C4 vette running 275-17's all around with lots of neg. camber
Thoughts ??
Thoughts ??
Thoughts ??
Thoughts ??
The cups are going to be hard to get up to temp in autox. With 2 drivers you will be close but you will have to give up the first couple of runs for sure. V710's would be my option. The almost have as much grip as the A6's and they should last a bit longer. You just really have to watch their temps.
I think the underlying theme to your post is looking for the best all around tire that can be driven to the track (unlike Hoosier) and work as a good R compound at the track while being streetable. Unfortunately there are many choices for cars that run smaller tires, but not a whole lot of choices for large Corvette tires in this category. So we get stuck with either the very high priced dedicated R compounds or some marginal street tires.
The best bet (and actually most economical) is to have 2 sets of tires, one for street and one for track. You will get the longest wear on both this way. Pushing street tires at the track could quickly eat up a set of $1500 tires and using R-compounds on the freeway, will do the same.
Like brake pads, a product that does both well and holds up just doesn't exist.
I’m starting to agree. Do you run Hoosiers? If so how many heat cycles do you get out of them. They are one of the only manufactures that make stock sizes.
I am able to get about a season and a half with a set of Hoosiers, if I rotate them and use them properly. I still have the same set of rears from Sept of 2007. I had to replace the fronts towards the end of the last season, but only because I run a very aggressive allignment that eats through front tires. If I ran a little less aggresive allignment, I could run them a little longer.
But with proper care and a good track allignment, you can get 8-10 track days out of a set, which for me is about a season.
You will find using each tire for only it's specific task will make them each last longer and work better.
