Lessons for Newbees
1 Post
Cruise-In II Veteran
Lessons for Newbees
Lets start a thread of tough lessons that we all have learned the hard way. Feel free to add.
1) Always open the fill plug, before opening the drain plug.
2) Never tighten any fastener until all fasteners are in and snugged up.
3) ...
3) ...
Could not agree more with the two statments above.
Ohh and from an experience last season with a newbie...... The brake grease goes on the back of the pad, not the friction side
Really LOOK at how something is assembled BEFORE you take it apart.
If the specs say torque something to XX ftlbs, then torque it to that.
The thinking "Tight is good so Tighter must be better" DOES NOT work.
When you change the oil filter. Check to make sure the old filter ring didn't stick to the engine. The cleanup takes hours depending upon how many seconds the motor runs before you realize what a boneheaded thing you've done.
Get jacking pucks that DON'T lock into the frame, at some point you WILL forget them after lowering and deposit them later on your favorite backroad, and/or turn 5 at VIR.
Make sure your hood pins are in before you roll off.
1. Make sure you dont leave wooden ramps in your trunk
2. Do not use your only ignition key to try and fix a jammed lock... it WILL bend
3. To prevent 1 and 2, do not bring a hot piece of *** to the track with you.
I am down to 3 pucks now. Also, make sure to remove the extra rotor from trunk well before starting track session. And finally, when people tell you a supercharger does not make a good track car, LISTEN!
