LT1 oil cooler setup
I have a NEW, GM parts, oil cooler setup from a chevy b-body, 9c1 police package. it will fit LTx motors. it;s the oil filter housing, all the hardware necessay to bolt the housing to the block. and the cooler lines from the oil filter housing to the front of the motor. the cooler lines run next to the oil pan, and mount to the motor using factory suppied hardware. all you need is an aftermarket oil cooler.
(because the b-body cooler can't bolt up, I never brought the gm cooler).
all you need to do is mount lines from any after market cooler, to the gm lines, and you pretty much have a GM engineered oil cooler.
$170 takes all.
$170 takes all.
