Best Clutch for 500 rwtq?
Old 02-15-2009, 04:01 PM
az55
az55's Avatar
Default Best Clutch for 500 rwtq?
I lost the clutch at Firebird East this week-end. These are on my list so far.
Excedy $2400+
Spec 3 $450+
Macleod $800+
I know Danny Popp swears by the Spec 3, but is it cheap for a reason? I find it hard to believe the Excedy is 5 times better. Is there some legitimate evidence that makes one better than the other. Most of what I've found is just hype. Any substantive opinions?
BTW, it is a time trials/racecar and I drive aggressively to say the least!
Cheers,
CV
Old 02-15-2009, 05:06 PM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
I really like the Spec Twin though would be overkill for stock power.
Originally Posted by http://www.eastcoastsupercharging.com/Clutches%20Corvette%20GTO.html
SPEC - SC 09PT Twin Disc Clutch
SPEC Super Twin Clutch Kit - Carbon Graphite Disk 1395 TQ Rating Corvette C5.
SPEC Clutches Super Twin is a clutch designed for street and track use in cars with big horsepower and torque at the rear wheels.
Until recently there has been a drivability, maintenance and longevity trade-off with clutches built to handle 700-1500 ft lbs tq. The revolutionary new SPEC Super Twin has set a new standard offering near-stock drivability, tremendous life expectancy, a no shimming/setup bolt-in installation and maintenance free operation.
* Billet construction these units are smooth and quiet.
* Constructed from aircraft grade aluminum
* High carbon billet steel milled to an industry leading .001 inch for perfect balance and actuation
* Dampened, full-faced carbon graphite discs provide friction
* Organic or full metallic options are available
Torque capacities upwards of 1500 can be realized depending on disc options.
Flywheel and track-spec hardware are included in each kit.
All units include: flywheel, high strength bolts and bearings. Installation is bolt-in with no shimming or setup required.
Old 02-16-2009, 09:59 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
The RPS street twin is a great clutch with very good street manners but it is a little pricey at $1700.
Old 02-16-2009, 11:33 AM
spazegun2213
spazegun2213's Avatar
excedy might pair up that clutch with a flywheel as well...
Old 02-16-2009, 12:17 PM
RAFTRACER
RAFTRACER's Avatar
I use SPEC 3 aluminum/aluminum (flywheel and pressure plate) , and it has not failed me yet . I routinely knock the snot out of them and abuse them every way possible.....Never have had any of the failures that I have heard about on this forum. The assy is 22 lbs. lighter than a stock clutch/flywheel assy and the cost is $1050~ish, so not quite the $450 that was quoted. My roadrace car makes 500~ish rwtq and more than that HP, So it ought to fit your application....
The Exedy weighs more than the SPEC, not sure about the McLeod or RPS.....
Old 02-16-2009, 07:35 PM
az55
az55's Avatar
Default Thanks Danny Popp
Danny, I appreciate you taking the time to help. It sounds like we have similar driving styles
That is still a lot better value than the Excedy. I wonder if the problems mentioned were caused by install errors versus product failure?
I will PM you if I want to talk further.
Cheers,
CV Wells
To Best Clutch for 500 rwtq?
Quick Reply: Best Clutch for 500 rwtq?
