Online Aerodynamics Model
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Posted over in C4tech
http://forums.corvetteforum.com/c4-t...post1568960321
I stumbled across an interesting Free Online flow simulator called “Flow Illustrator”
You can upload your own Bitmap images into it, so I figured I would try out a C4
Don’t know how accurate it is but fun anyway
See if I can get everything to post, got a little blurry eyed playing with this all day
The Bitmaps I made from a C4 technical drawing
And the Youtube videos, quality isn’t to good, unfortunately
Stock C4
http://www.youtube.com/watch?v=CPzo40SqO4E
C4 With a rear wing
http://www.youtube.com/watch?v=s_Rxn1Nc1dg
My C4 with a Greenwood Body Kit
http://www.youtube.com/watch?v=SRKqlwfylyk
& With radiator open
http://www.youtube.com/watch?v=oW8X5d5xllM
The home page for Flow Illustrator is
http://chernyshenko.sesnet.soton.ac....lustrator.aspx
You can modify & use my (24 bit) Bitmaps above
Click on bitmap and upload your image
2 :1 ratio images are best 640 by 320 , 512 by 256, etc
Re = Reynolds’s number = I used numbers in the 2,500,000 to 6,000,00 range
Dt = leave this alone, has to do with quality
Sec = video time – Anything over 40 sec takes forever.
Have fun!!!
Stock C4
C4 With a rear wing
Have fun!!!
Best height to place a wing
Optimal angle for a spoiler
Here's a C6
Here's a C6
And the C6
http://www.youtube.com/watch?v=Lsvc8thQXIE
For some reason, a few of these videos won't stop themselves?
I'm trying to figure out why
That shape caught my interest .... so I gave it a try.
Put in a little ground clearance and sized a wing to fit into the side plane shape.
http://www.youtube.com/watch?v=6qeIJZJKhv4
Something about these AVI files Youtube doesn't like ... still
The car has a flat bottom and side skirts which really help with air management. That "squared off" piece on the rear of the car (in my original pic) which you may have removed in your pic, is the race diffuser which definitely helps remove the air from under the car while creating a much smaller pressure drag profile from the flow coming off the back of the car.
Thanks for posting this!
Well, had some time to play a bit more with this program
Looks like you can use a 640 x 480 image, OK
I can than convert it over to an MPG for You tube
Also looks like the Reynolds Number isn't linked to the model size but the Bitmap size.
Everett, I had to take out the vertical surfaces (on the wing and diffuser) because this is just a 2D slice of the car & it would just see them a square blocks.
I assumed the diffuser was shaped like the rear of the car, but you can cut that in, any way you like.
If you try it again, here is the image I used, but you have to save it as a Bitmap, photo bucket converts them to jpeg, don't know why?
It's 640 x 480 pixels.
And I'm now using Re = 20,000 dt = .01 sec = 30 visual = 60
Takes about 12 minuets, you have to wait
http://www.youtube.com/watch?v=Bnj02Tk7D0w
The MT900's diffuser angle is 7deg...I know a guy, that knows the guy that designed it
Interesting piece of software. I'm surprised it doesn't show the high pressure areas on the front of the car, ie the lower windshield, etc., it could be a matter of scale, or maybe I'm just looking for too much.
I did find some info on the program.
It’s just a simple 2D modeler that seams to develop flow from the base Bitmap points and assumes all flow is Laminar. He tries to “simulate” Turbulent flow by using what he calls “Turbulent Viscosity” at higher Re values (=> 10,000).
Re number is based on the Bitmap and not the model size.
It should give reasonable results at sharp break off points (like the tail body edges), but the flow may separate at a different point (in real life) on long smooth surfaces (if they develop Turbulence).
I would use this to explore ideas, but not to design anything, for example:
I looked at Cowl Hood Scoops on the Vette and on a Honda Element. Both worked good with an empty engine bay, but when I started to fill up the void with parts (engines, etc.) the Honda kept flowing in (as expected), but at some point the Vette started flowing out?
So I wouldn’t use the program to design the point that the under hood pressure exceeds the windshield pressure (on a low CD vehicle), but more to get us thinking that maybe that does happen? Especially with an engine bay as tightly packed as the C4.
I also started played with things like MAF with and without screen.
I’ve got to get back to some “Real” paying work, but I’ll try to get back and post some more videos sometime.
Going to try to contact the author, this would be a great program for a High School Science or Science Summer Camp.
