Biggest Changes In 2009 Formula One Rules and Aero Design. SHORT VIDEO
Very short but awesome clip on the 2009 Formula One.
Interesting changes on how grip is reduced and how to offset it.
http://link.brightcove.com/services/...tid10497901001
Mike
Mike
Was it due to the KERS system having hundreds of volts?
I understand there are supposed to be warning lights to show the KERS status light, color codes and insulated gloves worn, but I guess that only goes so far.
Mike
1 Post
Cruise-In II Veteran
(745W/HP times 100 HP = 74,500 Watts times 2 seconds or 149,000 Joules.) And since a Watt is a volt-amp, you can do the math for a 100 volts, 12 volts or 1000 volts and it still makes for a deadly load of amps no matter how you do it. And if you did it with a flywheel, and it was damaged at say 100,000 RPM, that would be alot of shrapnel.
By comparison, a AA battery has about 3 Joules so the system above would be like 50,000 AA batteries zapping you at once.
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Great clip
Sorry to hear about the people killed
Niki Lauda on the changes
http://en.f1-live.com/f1/en/headline...20005011.shtml
