Seat Brace Question
Old 02-20-2009, 12:51 PM
sperkins
sperkins's Avatar
Default Seat Brace Question
For those of you with the r-dracing "Cross Bar". How did you attached your brace to the square tubing on the cross bar and which brand brace did you use? The more I think about a rear impact, the more it worries me that if my seat gives way, the 5 point harness is useless.
SP
Old 02-20-2009, 03:41 PM
Last C5
Last C5's Avatar
I've got a round bar so it wasn't a problem, but would square U bolts help the problem?
Old 02-21-2009, 10:29 AM
c4cruiser
c4cruiser's Avatar
Is there a specific requirement for any degree of hardness for mounting bolts/nuts for a seat back brace?
Typical U-bolts that are made for square tubing (2" in the case of the R-D Racing Cross Bar) are mild steel. It might be hard to come up with a U-bolt that's a Grade 5 or higher material.
Old 02-21-2009, 05:31 PM
trackboss
trackboss's Avatar
Grade 5 is plenty.
To Seat Brace Question
Quick Reply: Seat Brace Question
