I'm ready for the season to start. Thanks to PFADT Eng
Old 02-22-2009, 01:57 PM
Z06Fix
Z06Fix's Avatar
Default I'm ready for the season to start. Thanks to PFADT Eng
Spent yesterday at the shop going through the car and getting things ready to go. Installed the new shocks and mounted up some fresh rubber
I only got to put a couple miles on the car yesterday after the shock install, but I can tell you they are a HUGE improvement over the Bilstein sports I was running
The car feels so much more solid and responsive. It soaks up the bumps very well and does not get skiddish over rough pavement, even mid turn. I also feel like the I can get on the throttle earlier. The rear just feels so planted now. I played with the settings a bit and was very impressed to be able to feel a difference in adjustments I wound up setting them a 10 front and 12 rear. I will leave them there until I can get on the race rubber.
Big thanks to: Aaron, Robbin, and Jordan at PFADT Eng. They all were a big help and answering my questions
Our first local event is next weekend, then it's off to Dixie
Old 02-22-2009, 03:28 PM
spazegun2213
spazegun2213's Avatar
good luck this year! Pfadt ROCKS! their products are amazing and their support for them is unrivaled!!
Old 02-22-2009, 05:58 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
What's a setting of 10 versus 12 do?
Is that bump,rebound or some of both?
Do you have any shock dyno curves for 10 versus 12?
The reason I ask it that my QA1's adjust both.
And it sounds like the same settings I used to run at that autox
10f/10r otherwise it would start to hop
8f/8r on a road course
I run 4r/4r for the street.
1f/8r at the drags.
Adjustable shocks is the only way to go if you drive your car on the street.
If I leave them turned up, they'll rattle my teeth out!
Old 02-22-2009, 06:26 PM
tcmc5
tcmc5's Avatar
Bump and rebound are adjusted simultaneously.
Old 02-22-2009, 10:02 PM
LehmanZ06
LehmanZ06's Avatar
looking foward to Dixie
Very nice looking yellow car
Old 02-24-2009, 07:54 AM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
Seriously? Are you sure? I have no idea whay you would want to do that.
Old 02-24-2009, 09:15 AM
AverageVetteNut
AverageVetteNut's Avatar
Cruise-In 9-10 Veteran
CI-X Auto-X Champ (race tires)
St. Jude Donor '07-'09
Hey... car looks good. Can't wait to hear about how it works.
I should be at the event this weekend in Knoxville, and might even run if the weather co-operates and I take the Z06 on my trip. I will have to stop by and say hello when I see ya.
Old 02-24-2009, 11:20 AM
Pylons
Pylons's Avatar
Yes, that's how the Pfadt's work.
Not optimal, but they're cheap and I'd rather have only one adjustment to mess up than 2 at this point.
Old 02-24-2009, 11:52 AM
BrianCunningham
Konis have one adjuster, but it's only does one, rebound or compression, forget which since I don't own a set.
Old 02-24-2009, 11:55 AM
Pylons
Pylons's Avatar
It's rebound-only on SA Konis.
Old 02-25-2009, 10:25 AM
Z06Fix
Z06Fix's Avatar
Very cool. It's going to be cold one for sure. I believe the high is showing 48 the last time I checked. The rain should be out of here Fri night or at the lastest Sat morning. Sun looks dry
By all means come by and say hi. It's always good to meet fellow CF members
I'm just using this event to get the car dialed in for Dixie.
Old 02-25-2009, 01:46 PM
jordan@pfadtracing
jordan@pfadtracing's Avatar
St. Jude Donor '08-'09
Autocross & Roadrace Forum Sponsor
Eric,
We're looking forward to hearing how your event goes! The car looks great! Thanks for the kind comments and welcome to the Pfadt Race Team!
Old 02-25-2009, 02:09 PM
AverageVetteNut
It's only going to be 28 here on Sunday for a high, so I won't be driving the Z06 down afterall, but will have the Cobalt SS in snow tires...lol
I WILL come by and say hi. I was going to do the same back when I was registered for Dixie, but it's too far a drive from here.
Old 02-25-2009, 02:23 PM
jordan@pfadtracing
Our adjustment adjusts both rebound and compression in a ratio of 3:1. We've developed the valving to make it easier to adjust for the vast majority of people that don't need or want double or triple adjustable shocks. Having the ability to increase or decrease the damping is very important for different track or road conditions. Keeping the adjustments in line is important, with multiple adjustments you can negatively effect the handling and most people want to drive there cars and they don't want to adjust the shocks all day. We're not the only quality shock company that has this option, in fact almost everyone does.
The adjusters on our shocks are on the bottom and you can adjust all 4 corners in 5 minutes without tools or raising the car. We have a lot of customers using them in T-1, Super Stock as well as the street. Given the Value, quality and functionality you can't beat them! They are a great value at $890 for a complete set!
Old 02-25-2009, 04:26 PM
Datawiz
Support Corvetteforum!
Datawiz's Avatar
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
OP, see you in Dixie! Hope we both represent Pfadt well.
Old 02-25-2009, 06:50 PM
AverageVetteNut
I'm looking into suspension choices for either this year or the next season, so I will want to see how the car handles for sure... also how they work.
Old 02-26-2009, 08:56 AM
shifter77
shifter77's Avatar
GOD SPEED
To I'm ready for the season to start. Thanks to PFADT Eng
Old 02-26-2009, 02:46 PM
waktasz
waktasz's Avatar
What are your spring rates compared to a stock z06? Your shock settings are way different from what I'm using in super stock.
Old 03-02-2009, 12:13 PM
Z06Fix
Z06Fix's Avatar
Running stock springs. I have not had a chance to get on the race rubber with them yet. So I may very well end up changing them. What are you running yours at?
I have heard anything from 8-11 front and 10-16 rear. I just didn't want to mess with them a whole lot since the car acts so different on race tires, compared to streets.
Old 03-02-2009, 12:15 PM
waktasz
waktasz's Avatar
I'm running Konis, but I'm running them much stiffer in the front than the rear. Maybe you are too and I'm just reading your settings wrong.
Quick Reply: I'm ready for the season to start. Thanks to PFADT Eng
