NAPA rotors, which ones??
Old 02-25-2009, 07:32 PM
spiral04
spiral04's Avatar
Default NAPA rotors, which ones??
I'm going to buy a cheap set of rotors for the track I'll be going to Spring Mountain next week. Napa has 3 to choose from. Like $110 each is out, $45 each, or $22 each(surely chineese). Which should I buy for the track? TIA
Old 02-25-2009, 08:19 PM
CHJ In Virginia
CHJ In Virginia's Avatar
All the NAPA rotors are Chinese ! the expensive ones are drilled / slotted -- no way. The $45 ones are exactly the same rotor as the $22 one except that the hats and radial edge of the rotor are painted black. I had 2 cracked ones and the local store owner had the NAPA rep stop by to view the crappy product. I ended up with a replacement set of fronts free. My preference is the cheapest - take a set of spares ! Be sure to properly cool them down after each session and you will minimize cracking.
Old 02-25-2009, 08:27 PM
spiral04
spiral04's Avatar
Thanks! Now I just need a set of pads and almost ready to go!
Old 02-25-2009, 09:02 PM
sperkins
sperkins's Avatar
I usually buy OEM rotors cheaper off of other forum members when they go for bling instead.
Old 02-25-2009, 09:20 PM
klasik-69
klasik-69's Avatar
Cheap rotors !! not worth the savings, especially if one cracks and flies apart. I can see buying cheap underwear, cheap shoes, maybe a cheap pair of gloves.............but cheap brakes
OEM rotors, or better yet, DBA 4000 slotted rotors ($147 each), and you'll find they're actually cheaper in the long run, and you won't be hyperventilating while on the track worrying if you mailed in your life insurance premium. I've attended level I and II schools at Spring Mountain. The track is demanding if you drive it aggressively, heavy braking coming off the straight. Don't cut corners with brakes.
Old 02-25-2009, 09:30 PM
johninar
johninar's Avatar
Cheap Napa works for me. I can melt the rubber off the boots without cracking the rotors. Proper cool down lap, and move the car in the pits after stopping for a minute or so, and they work great.
Old 02-25-2009, 10:02 PM
Last C5
Last C5's Avatar
Cheap NAPAs (or cheap anybody's) work as well as anything on the track. Take your cool down lap without touching the brakes and after you pit move the car about a foot every couple minutes or so for a little while to keep section of the rotor that's inside the caliper from remaining too hot while the rest is cooling.
Old 02-25-2009, 11:28 PM
Davinss
Davinss's Avatar
Cheap napas work for me! I have been through many sets!
Old 02-26-2009, 12:02 AM
spiral04
spiral04's Avatar
Thanks for all the responses guys. I'll be headed tomorrow to Napa to get the $22ea. rotors and some dot 4 brake fluid. Now if I could just find a good set of used track pads, I'd be good to go. I can't wait for my first time at Spring Mountain!
Old 02-26-2009, 08:37 AM
AlwaysInBoost
AlwaysInBoost's Avatar
could someone post the PN for the cheap $22 rotors?
I'm going to be installing my cooling ducts in the next couple weekends before going to LIghtning and I'd like to replace my blingin drilled/slotted/vented rotors.
Old 02-26-2009, 11:02 AM
spiral04
spiral04's Avatar
I will be getting them later on today. I will let you know the part #'s.
Old 02-26-2009, 09:19 PM
spiral04
spiral04's Avatar
I passed on these and am going to get my feet wet first at the track before doing anything else. Thanks for the help!
To NAPA rotors, which ones??
Quick Reply: NAPA rotors, which ones??
