295/35/17 A6/R6 Ok for 17x9.5 C5 Zo6 wheel?
Old 03-01-2009, 09:58 PM
sperkins
sperkins's Avatar
Default 295/35/17 A6/R6 Ok for 17x9.5 C5 Zo6 wheel?
I know most guys run 17x11's, but anyone running these tires on stock C5Z wheels?
Old 03-01-2009, 11:50 PM
Z06Fix
Z06Fix's Avatar
295/35/17's fit perfect on the stock 17x9.5" wheels.
Old 03-02-2009, 06:25 AM
greendot
greendot's Avatar
Old 03-02-2009, 08:04 AM
AverageVetteNut
AverageVetteNut's Avatar
Cruise-In 9-10 Veteran
CI-X Auto-X Champ (race tires)
St. Jude Donor '07-'09
Yep, that's pretty much what most ( I've not seen anyone NOT running them ) of the C5Z stock class autocrossers are running up front.
I'll be running that when they come in as well.
Old 03-02-2009, 09:19 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
That's what I have on all 4 corners.
Old 03-02-2009, 12:14 PM
Kanmer
Kanmer's Avatar
Cruise-In VI Veteran
Thats what I run up front on Amolds 17X9.5 with 295's
Old 03-05-2009, 01:16 AM
fatbillybob
fatbillybob's Avatar
The hoosier guy topless performance says the 295 17 was designed for Pbugs to get more rubber but stay in class with their wheel size per their race rules. That's why only Hoosier has the rim size starting at 9.5" for such a wide 295 tire. We can benefit because we can use those 295 17's on our 9.5"x17 C5Z wheels and either run that on all 4 corners or do a 295 or 305 on the 10.5x18 stock C5Z wheels. I also find that doing a square set-up takes some of the understeer out of the car.
Old 03-05-2009, 10:18 PM
R Mackow
R Mackow's Avatar
With 17x9.5 + 17x11:
A6s: 295/315
V710s: 275/315(don't use 295 it screws w/the ABS.)
Old 03-06-2009, 01:26 PM
waktasz
waktasz's Avatar
I didn't have any problems using 295/315 Kumhos last year.
Going Hoosier this year though.
To 295/35/17 A6/R6 Ok for 17x9.5 C5 Zo6 wheel?
Quick Reply: 295/35/17 A6/R6 Ok for 17x9.5 C5 Zo6 wheel?
