Partial Cure Found for Overheating C4 Brakes
Old 03-10-2009, 01:36 AM
Sidney004
Sidney004's Avatar
Default Partial Cure Found for Overheating C4 Brakes
Get rid of the sawblades! Switched to the 18" Z06 wheels and they have superior cooling.
Old 03-10-2009, 03:30 AM
flink
flink's Avatar
yep. Do your brake bed-in at night and watch the
direction in which the sparks fly - there's strong air flow outward
through the wheels. You don't want to block it off!
This also explains why the outboard pads wear faster (mine do, at
least). They're on the downwind side.
I am told that Harrop found that wheel design makes a "huge"
difference in brake cooling.
You'd think that race wheels would be designed like fan blades...
Old 03-10-2009, 09:50 AM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
It it the sawblade design, or the fact that you went to a bigger diameter wheel, so there's more room for the calipers to breath?
I'm running 18's on the front as well.
Old 03-10-2009, 10:28 AM
Sidney004
Sidney004's Avatar
I think both but the Z06 design is very "open" and promotes cooling.
Old 03-10-2009, 11:26 AM
Aardwolf
Aardwolf's Avatar
I went from the pretty enclosed stock 17" '88 wheels to the really open C5 thin spokes and didn't notice a difference. Running real track pads made a nice difference though!
Old 03-10-2009, 03:08 PM
eogel
eogel's Avatar
Four of us who road race C4's had severe overheating problems when we upgraded to Wilwood calipers. Mine was resolved by two things: 1) increasing the air to the brakes with more ducts; 2) stop using the brakes so much (seriously!). I am not sure which one was the most effective, but using the brakes less and being more efficient with them also decreased lap times.
Old 03-10-2009, 03:59 PM
StArrow68
StArrow68's Avatar
Sidney already found the 2nd item, he never slows down!
To Partial Cure Found for Overheating C4 Brakes
Quick Reply: Partial Cure Found for Overheating C4 Brakes
