Koni 3013 questions
Koni 3013 questions
I picked up a used set of 3013's (newer inverted sport version) to experiment with this season.
Looking at Koni's web site, it says that there should be 12 swipes (3 turns) of adjustment in them. I can only get around 8 swipes with these (I have taken the ends off and turned the adjuster directly and can only get 2 turns). Given their reputation for sticking, I don't want to attempt to force the issue.
I'm figuring that Koni's adjustment info is a general guide and that some versions don't have as much adjustment as others, but just thought I'd see what other folks experience is.
Anyone care to share a starting point (SS '02 C5Z, 32mm hollow front bar)? I've been told 0-1 swipes from soft on the rear, but not sure about the front.
Thanks,
Kenton
Thanks,
Kenton
Thanks,
Kenton
Thanks,
Kenton
You have the same set up that I do. I only get 8 sweeps. The web site probably isn't accurate. I count the sweeps from full soft. I run 5 on the front and 2.5 for the rear.
These settings seemed to work well at nationals.
Hopefully I'll see you up in Milwaukee soon!
Chris
Just who I wanted to hear from!
Thanks Chris. Yes, those setting worked quite well for you.
We'll be up for at least the divisional. We'll have to see how our schedules work for the rest of the year.
You can always fallow Steve down to some of our events (the border isn't a one-way)!
Thanks again,
Kenton
Thanks again,
Kenton
Thanks again,
Kenton
Thanks again,
Kenton
