This post is going to take 3 weeks to finsh (videos and/or picture updated often)
Old 03-16-2009, 02:05 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Default This post is going to take 3 weeks to finish (videos and/or pictures updated often)
We advertised here on the Corvette Forum this concept of building a inexpensive C6Z for the HPDE, Open track, Club racing, and ect.
Here we are on the last couple of weeks before the shake down test @ MAM on 4-11 and 4-12. I hope you enjoy this thread, as it will be updated almost everyday as we get closer. Then the customer will be running the Big Bend open Roadrace with his son in later April!!!
Here is part 1 of the build. Sorry No music yet, DRM jiggle will be added at a later date.
Randy
www.dougrippie.com
763-477-9272
Old 03-16-2009, 03:54 PM
mgarfias
mgarfias's Avatar
I was going to ask how you attached a steel cage to an aluminum chassis. Then I realized you were using a steel chassis. Which made me think of something else:
Why didn't you change the rear upper a-arm mounting to be like the C6Z, or the front upper arms that use a cross bar through the bushing and bolting to the frame?
That'd offer easier camber changes, and I doubt it'd be much additional work to retrofit the chassis with it.
Old 03-16-2009, 04:08 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
The front is the cross bar style, you can adjust the camber either on the lower arm or on the top arm, with shims. The rear camber adjustment is done on the lower arm. Not worth the cost of changing around the rear upper mount for the little benfit.
Randy
Old 03-16-2009, 04:54 PM
KBlanke
KBlanke's Avatar
Very nice.
Old 03-16-2009, 05:44 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Damn nice seat!!!
[IMG][/IMG]
Old 03-16-2009, 07:05 PM
CHJ In Virginia
CHJ In Virginia's Avatar
Wow - that is a fine piece of machinery - now all I need to do is pick 6 for tomorrows lottery drawing !!
Old 03-16-2009, 10:31 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Randy
Old 03-18-2009, 11:53 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Randy
Old 03-18-2009, 12:44 PM
Z06Fix
Z06Fix's Avatar
Very nice
Old 03-18-2009, 04:26 PM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
Very nice!
Old 03-18-2009, 04:29 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Nice clean installations
Old 03-19-2009, 04:33 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
If the front end comes off again, I will snap a picture of the front bumper also.
Randy
Old 03-19-2009, 09:27 PM
froggy47
froggy47's Avatar
That's some nice work, good to see you are keeping busy.
Old 03-19-2009, 09:38 PM
RoganR
RoganR's Avatar
Looks like you are putting something together that is going to be real nice.
Old 03-20-2009, 07:42 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Unoffical, + or - 10 pounds. The car has no weight for driver and a couple gallons in the fuel tank.
Doug and the customer are in a heated battle of guessing the exact weight. It's down to like four or 5 pounds. It's for steak dinner Friday or Saturday night.
Randy
Old 03-21-2009, 12:16 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Good night!!!
Randy
Old 03-21-2009, 12:53 PM
ajg1915
Support Corvetteforum!
ajg1915's Avatar
St. Jude Donor '08
Very nice craftsmanship.
To This post is going to take 3 weeks to finsh (videos and/or picture updated often)
Old 03-23-2009, 02:01 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Saleen S7 Power-to-weight ratio: 0.254
Porsche Carrera GT Power-to-weight ratio: 0.198
Ferrari 599 GTB Fiorano Power-to-weight ratio: 0.166
Mercedes-Benz SLR McLaren Power-to-weight ratio: 0.164
Lamborghini Murcielago Power-to-weight ratio: 0.172
Morgan Aero 8 Power-to-weight ratio: 0.13
Viper Comp Coupe Power-to-weight ratio: .174
Stock C6 Z06 Power-to-weight ratio: .159
Stock C6 ZR1 Power-to-weight ratio: .190
Enzo Ferrari Power-to-weight ratio: .216
DRM Car Power to weight ratio: .23333333
Old 03-23-2009, 02:02 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
One more interesting figure. The guys on the C6Z forum are winning the post war 48 to 17 on this thread.
Randy
Old 03-23-2009, 02:03 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
For the euro guys
496.79KW/1227.27KGS = .383
Randy
Quick Reply: This post is going to take 3 weeks to finsh (videos and/or picture updated often)
