Kill Switch Installation into 2007 Z06
2007 Z06-- Kill Switch Installation
I am looking for any learnings I can get regarding installation of a Kill Switch into a 2007 Corvette Z06. We have built out a 2007 Z06 for racing in NASA and SCCA and when we installed the Kill Switch into the car, we seem to have the computer going crazy with the kill switch and turning the lights on and off while driving and sending message displays indicating Service the Charging System, Service ABS, High Voltage on Battery and then the computer resets and clears the messages and then starts again. Anyone have any recommendations or experience with installling a Kill Switch in the 2007 Z06? Thanks in advance for any advice or insight you may share?
1 Post
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
You know this guy Tony had the same problem down at Road Atlanta this weekend.
It was great meeting you also. You looked great on the track---plan to come back this summer when we get some good track conditions. You car looks great and I am anxious to see how fast it can turn the dry track conditions. Glad you got home safely after a long day on the track. Best wishes and keep in touch. Tony
You need a 6 post switch Not a 4 not a 2. You need to kill the battery and the alternator. That's why you get the other messages because your alternator is running the car when you kill the switch. You need to be wired soemthing like this. http://spece30.com/images/fbfiles/im...illswitch6.JPG
After you get your switch I can send you pics of exact wiring to the alternator on my C5Z. You need to set it up to kill bat and kill alt so when flipped the engine dies or you will not be SCCA or NASA legal
I haven't done a C6Z, but I always use a 2 post, and simply move the alternator wire to the "battery" side of the switch, instead of the "engine" side of the switch. This leaves you with a single hot wire going to the alternator all of the time, but otherwise works perfectly.
I'm thinking, as said, the inconsistent voltages are being caused by the switch you are using, but whether it's the switch's fault, or the wiring setup, is hard to tell here. You must be having spikes/dips while the engine is running??!!
Thanks!
I haven't don't one in a while, basically the big wire that goes from the alternator back to the main hot circuit needs to be removed, and re-attached to the "hot" side of the switch. It normally allows the alternator to keep the engine running if you cut the power, but by moving it you eliminate that. The easiest way is to leave the OEM alternator wire in place (tape it securely), and run a new hot wire from the alternator back to the hot side of your switch. It's always worked for me, and I use the $6 switches from WalMart.
Is it possible for a C6 Corvette to still run without a battery and alternator?
no, I don't think so. If you cut the power and it's still running, you've got a leak somewhere. You have to have the PCM, fuel pump, coils charge as a minimum to keep the car running........maybe you added the flux capacitor option??
Without that, everything shuts down but then I have to drive it for 30 minutes to reset the computer.
With it, the kill switch then did not shut down the engine
Its just that I will have to drive the car for 30 minutes on some back road everytime it is teched and tested by NASA
We tried a KAM 9 volt battery through the cigarrette lighter and that did not work. It must work on some cars because they sell them for that express purpose.
Thats were we are with it now. It works great and will meet NASA rules.
http://www.aa1car.com/library/batter...t_problems.htm
