Auto X class help - experts needed...
My local SCCA region is having an event this weekend and a buddy of mine and I are thinking about entering. I read the SCCA rules as much as possible, but there are literally 346 pages.
What class would we fall under?
CAR 1:
2003 C5 ZO6
Only modifications:
Front and rear sway bars
275front /305rear R compound tires
Removal of factory air box for K&N filter.
CAR 2:
2007 C6 Z51
Only modifications:
Vararam air filter
Headers / cat delete
Thanks in advance,
SP
CAR 1:
2003 C5 ZO6
Only modifications:
CAR 2:
2007 C6 Z51
Only modifications:
Vararam air filter
Thanks in advance,
SP
Car #1 would be ASP for sure. as the rear sway bar throws it in there, as does the Airbox modification.
Car # 2 MIGHT be ASP since the headers are there, but I'm not sure since the cats are gone.. that might throw a kink in it. If not , it would be in SSM ( formerly SM2 ).
I THINK you still need to have some kind of Cat in SP trim, but I'm not 100% sure.
If I was home, I'd look in the rulebook, as it's easier than looking on the online PDF.
yep...smells like ASP for both to me
but you'd be eligible for other classes like SSM (and maybe XP?) if there were folks in those classes you wanted to compete directly with
ASP
BSP
CSP
DSP
ESP
FSP
All "SP" configued C5 & C6 vettes fall under "ASP" and C4's fall under "BSP"
If you are going to run with your buddy be sure to register in the same class so you can have some fun with each other. Loser buys dinner or something like that. That way you won't be worried about how others are doing, only how you are doing vs. your buddy.
Just have fun.
Just have fun.
