Tire Pressure
Tire Pressure
I am going to a track day at Texas World Speedway with The Drivers Edge folks and was wondering what tire pressure I sould start with in my C6 Z06 with stock run flats
Thanks in advance
Thanks in advance
I used 31psi F&R when I did my TT on the run flats in my C6 Z51. I don't know if the Z06 is any better, but 2-3 laps is the most I can get out of the tires before they overheat and I slow down.
Not sure if runflats are any different than regular, but I was under the impression you needed to be at 38-39 lbs when heated, so whatever it takes to start out to get to that. I would like to hear more input on this.
