C6 Wheel Options
C6 Wheel Options
Is anyone running C5 speedlines on their C6? Do the C5 wheel offsets work on a C6? I'm looking for economical alternatives to run 18s all the way around on my C6. 19 inch race tires are hard to find used.
I have an extra set (repos) of C5 Z06 rears I don't need. I run a set with 305's. No issues. I had the Speedlines and sold them since I could not tell any difference and this wheel is every bit as strong.
I use a C5 rear wheel (18) on the front with a 275. Works very well and scrubs (R888's) are easy to come by for all.
These wheels are cheap, strong and for track that is all I need.
they should work fine, however don't be surprised if you get a bit of scrubbing here and there if you go with really large tires....this is true of any wheel.
I tried some Repro's, but they were 9lbs heavier per wheel than the Speedlines. I sent them back and paid the extra for the OEM's
