C5 rad/diff coolers, what setup are you running?????............................ .....
Cruise-In VII Veteran
1. Diff, I'm installing a RPM built C5 diff w/ a C6Z06 rear cover pump, using a Moroso cooler mounted on the rear xmember, real tight w/ the stock Ti exhaust in place
Just wanted to see what the track crew is running
thanks
thanks
My car doesn't have the cutouts either so I cut a rectangle in the rear tub, behind my tag, and built a structure with both heat exchangers mounted side by side. I also cut the center out of the rear floor, allowing the pumps to sit on the passenger's side of the rear horizontal frame rail and the lines are short and run through the tub.
Just another idea, but back to the side ducts, if you have them, go DRM for sure. Randy Rippie is a pleasure to do business with.
I've installed the DRM cooler for the transmission and differential, I ended up fabricating brackets to mount the pumps and radiators just inside the rear wheels (one set on each side).
Works great and after about 15 HDPEs, runs cool and no problems.
