Question: Mix MPSC & Hoosier R6 ???
Old 03-21-2009, 12:50 PM
Dirty Howie
Dirty Howie's Avatar
Default Question: Mix MPSC & Hoosier R6 ???
Thinking about putting MPSC's(285x35x18) on the front and running with my R6's(325x30x19) on the rear. This is for track only
Has anyone done this??
Do you think they are compatible??
DH
Old 03-21-2009, 01:31 PM
AU N EGL
AU N EGL's Avatar
very very different rubber compounds. May not be a good idea.
Some guys have tried Rs and As combos and found that did not work either.
Old 03-21-2009, 01:52 PM
Lancer033
Lancer033's Avatar
MPSCs are the pilot sport cup tire right? If so, I would think that mixing a 100 treadwear front tire with a 30 treadwear rear tire would generate a lot of understeer.
Old 03-21-2009, 05:20 PM
kelp
kelp's Avatar
Uh oh. Wonder if that will get past tech.
Old 03-21-2009, 08:22 PM
Dirty Howie
Thanks guys, I have decided this is a NO GO.
It was explained that different tires reaching different operating temps at different times is a BAD IDEA
DH
To Question: Mix MPSC & Hoosier R6 ???
Quick Reply: Question: Mix MPSC & Hoosier R6 ???
