Where to get tires mounted and balanced in GA
Somebody hook me up here.
Butler does the true high speed on car, but they want $120 for 4.
Kauffman only spins and says good to 75mph and want $25 per tire.
NBT wants $60, but they too only spin off car.
Tiresplus is right next door to me, but I get tired of going back because they are incompetent and need to put weights on outside of wheel to get it right.
Ken . . .
Ken . . .
I using browning next to road atlanta. stick ons and they'll HVAC tape 'em for you to.
I don't put much effort into doing race tires, once when new, maybe again 1/2 through they're life (if they get bad). it's hard to keep them balanced, as much rubber as you rip off of them.
I've found it's not so much the facility/place of business, as it is the actual tech you are dealing with.
I do know that a tire machine is rapidly moving up the list for the shop...
I'm trying to get some PS2's mounted for the drive up and in case we catch a rain day. Then I have another full set of rims where I just corded my V710's, so I'm looking for a good set of used v710 / RA6 / R6 race tires for those. And of course those will need to be done over and over. Or maybe not, so let me ask --
If I broke down and spent the 1k on a new set of 275/40/17 V710's how many Chin double day events would I make it through before cording them? This year I will probably do Road Atlanta 2 times, Roebling in Nov, Barber once, CMP once.
Something to consider. When I raced T1, I would buy a new set of Kumho for every national event. When they remounted the new tires, I left the old ones there...most times they only had 5-6 heat cycles on them. Some guys from the local corvette clubs would come up and pick them up. Lots of time they would actually bring the wheels to the track and have them mounted and spun right there.
Ken . . .
Ken . . .
Former Vendor
Ken,
Go to Discount Tires at Discover Mills. They have done a lot of work for me and have never been less than perfect. Doug is the manager there. Talk to him and let him know your expectations just to be sure, (although not necessary) and you will be taken care of, and save a lot of $$$$.
When I got my iforged wheels 3 and a half years ago, I went to butler too. They charged me full price for dismount and mount, as if I had 2 sets of tires! Swapping tires from one set of wheels to another, and an alignment cost me $400!!!!!! Never again.
Only one place to go...Gran Turismo East. There are times to save money and times to spend what it takes to get it done right.
Those guys do a good job also very good for track alignment..
For those on the southside i use a shop in Griffin , Mr NOBODY, they have done a gr8 job quick and reasonable no vibration issues. also make sure that the shop you use is experienced with race tires, you should not use as much pressure to seat the bead.
I also agree with Bob on a new set for every national event. am building up quite a stack of 275 35 18 tires.
Spoke with the GranTourismo guys. Very cool speaking with them as they know what they are talking about. Still pricey at $25 per wheel. They actually broke it down for me
$12 Mount
$8 Balance
$3 disposal to throw old rubber away
$2 new stems
And that is just the spin balance, another almost $40 for the high speed on car balance.
$12 Mount
$8 Balance
$2 new stems
