Gto / vir
Gto / vir
Why did we not see many GTO's out at the track ? Seems like they would have made a "ok" track car.... Ya see just about everything else out there but I only recall seeing 1 out there.....
Just wondering
Just wondering
"AlohaC5" Senior Member
I've seen a couple of GTOs at Watkins Glen - they performed well. I think they would make a fun track car. I think I've only seen one at VIR over the past two years - none at Summit Point.
First of all, they didn't make that many so they are a bit rare. Second, they are an ok track car. A Corvette is much better. I have an 04 GTO and for the track it is under equipped in the brake department, under sprung and in desperate need of a harness bar. It is a bit on the heavy side and you can't get very wide tires on it. I love the car but it needs a lot of help on the track.
I would never compare a GTO to a Corvette - maybe a Mustang GT. The two I saw were modified (engine, brakes and suspension) - the owners were having a good time. Heck, that's all that matters. Definitely no competition for a Corvette.
1 Post
Cruise-In II Veteran
Well, we do have a very nice harness bar for it. It is not a huge seller, but it is obvious that some people do track them.
http://hardbarusa.com/hardbar/produc...products_id=62
cool maybe it is the demographics it was marketed to .... I see a lot of them on the 1/4 mile saw one cheep around here and just though hummm a D/D and light duty track car.... Never could it compete with my Z06 but still may be fun to learn a new car...
I'm taking mine to Autobahn in Joliet, IL following weekend for first track day, can't wait
Going to put KW V3 coilovers and 17x9.5" OEM C5 Z06 wheels to work finally.
I see them occasionally on track - here in the SE we have one that runs TTA - he normally finishes after the top running Vettes but ahead of some of the others. My wife has an 05 GTO and she loves it. I have tracked it twice - what a hoot. It is heavy, it does not have enough tire, it does not have enough spring and it needs aftermarket brake pads - but the grin factor is definitely there.
How are you going to bolt on C5 wheels? The GTO has a BMW lug pattern.
The BMW lug pattern and the Vette are the same (if not nearly so). 5 on 4 3/4 or the metric 5 on 120.65mm some quote 120mm. That 0.65mm is only a .025 inch difference that is well within the tolerance stack-up for the hub, lugs, wheels and wear from usage.
It's cool to see some GTO's in circulation. Like I said, they only build about 14,000 a year for 3 years so they aren't very common.
For front I have custom adapters on the way from Skulte that will convert the bolt pattern and be hub centric. They're 20mm so it will bring offset down to 34mm, which will be perfect and have room to dial in some negative camber.
For the rear, I'm just going to bolt the wheels using a hub-centric ring to take slack from 69.6mm to 70.3mm. 54mm Z06 offset is spot on for the back of GTO. Like burners said, the bolt pattern difference is minimal.
some former crew members of mine worked on Stu Hayners GTO World Challenge team, and they had an AWEFULL time getting the rear suspension to perform at all competitively. They ultimately imported the Holden rear setup from Australia.
I personally like the GTO, but it was basically a Camaro/Trans Am replacement, and I think it's track performance is pretty much on par with the previous gen F-body.
That looks pretty tough! I like that a lot but I would be concerned about fender rubbing. Without some stiff springs I think body roll will make contact with the tire. That's why I'm working on an improved front suspension for my GTO that will have more (well, actually have) neg. camber gain with body roll. That and I need to make some fender flares.
In one sense I disagree that the GTO is an F-body replacement because it makes a much better family car. I directly compared the two and the GTO is much better. As for the track, well, yes I agree.
One of the members here, flink, set his up for track pretty good. -4* front camber, -2.8* rear camber using eccentric bushings, KW V3 coilovers, and NT01s. He seems to run pretty good on tracks out west
It actually clears the fender somewhat, but I suppose it could still rub when wheel is turned. I drove around for couple days to test and it hasn't rub, so I think it'll be fine, though.
What are your plans for improving the suspension?
I'm working on a design for an a-arm front suspension with coil-overs. It should make for much more adjustability and better roll centers. One of the few things about the suspension on the GTO that I wasn't happy about was the macpherson struts.
Wow, nice! Please keep me updated on that. I'm sure a lot of people on GTO forum would like to see that done. flink always complains how he hates McPherson haha.
Peddars imports/makes a rear bushing kit that is supposed to really help out.
I'm only running RE01r 255/40 tire, but it seems perfect size for 9.5" wheel. I was planning on running 275/40, but I couldn't pass up the prices on RE-01r...
Instead of grip, I would be more worried about the brakes. I took a student's car out for 2 laps @ VIR, the brakes were definitely roasted at that point. Car leaned a lot, but it still feels okay.
Did it have stock pads? I'm upgrading to larger 05-06 calipers and rotors and I bought some EBC Yellowstuff pads. I know those pads aren't one of those hardcore track pads, but for a beginner like me should be fine.
