What track tire sizes fit on stock '00 frc rims?
I thought that i'd simply be able to hit tire rack for my tires but there are no competition tires in the stock sizes.
What sizes will fit safely onto the stock rims? I'm looking to stay in the
stock class hence the stock rim sizing.
THanks!
THanks!
I'm running 275/305 Toyo RA-1s on stock wagon wheels. They work just fine, tire wear is as even as anyone else, and my alignment settings are basically Z06 settings.
HTH, and have a good one,
Mike
Mike
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
VetteDrmr-- very cool info, thanks for the post... I've been debating on getting z06 rims for the extra width, but this saves some $$! No problems them with fitting on the narrower rim? Or body rubs?
How do you like the toyo's?? I've never run them before, curious how they compare to the NT01's, and others?
thanks!
Dan
thanks!
Dan
I've not run the NT01s, although Nitto and Toyo are made by the same company; my guess is they'll be fairly close. As far as fitting on the narrower rims, I've never had my tire mounters complain and I always tip them for the work done.
No body rubs at all. Just fat meaty tires on cheap strong rims!
Have a good one,
Mike
Have a good one,
Mike
thanks. I was actually thinking of using the stock magnesium rims that came with my c5... they have some bald run flats on them still. Plus they should be light.
They are light, but I *really* would be cautious with using mags. You have to worry about the clear coat getting scuffed and the alloy oxidizing, and I haven't heard of much experience with them from a bending/cracking point of view.
Not saying they won't work, and work well, but they are a bit of an unknown.
Have a good one,
Mike
Have a good one,
Mike
Thanks for the info...i'd love to get a set of race tires/wheels asap for the coming season. Wagon wheels sure can be had CHEAP!
They are fairly ugly but somebody on this forum was selling some black wagon wheels with a red lip, i believe. They looked great! (winter project!)
Thanks again for the info...i'll probably be sticking with the tried and true Kumho brand. I loved the victoracers just for the longevity!
If you are autocrossing and want to stay in SS or IH class then Hoosier 275/40/17 fronts and 295/30/18 rears work very well. If you take that set up to the track, it is important that you check the "rake" of the car for better handling. That is basically a square set up.
If you are new to autocrossing on competition tires, then another tip would be short shifting into 2nd for most of your events. The Toyo's and Nitto's will last longer but the Hoosier A6 and the Kumho V710's are considerably faster.
Rake is the ride height of the rear wheels and the front wheels. The easiest way to measure is at the jacking points, you want the front point at least 1/4-3/8" lower that the back. When I run autocrosses, I turn the active handling off, when Time trials/HPDE I usually run in competition mode. Active handling still works with a 275/295 set up.
Also you will have to consider a compromise on the alignment. For a double duty car you want about 1.2 to 1.5 neg camber in the front and about 0.7 rear. 0 toe and all the caster you can get--balance the caster. Rear toe about 1/16 toe in.
