PS fluid recommendation?
I give up on the Search function. I haven't had any real problems with my PS system (Z51 cooler stock), but it's been a while and I was wondering what's the current coolest, most awesome, spectacular, fluid to use in a PS system these days.
TIA, and have a good one,
Mike
Mike
I had been using off-the-shelf PS fluid in my 87 and track days would cause a fairly loud whine from the pump after a couple sessions. I switched to Red Line Synthetic and the original PS pump is quiet now.
I used to use the synthetics until someone recommended fluid from Lee (Automotive?) in CA. They do the ps systems for circle track racers. Seems like a good background for knowing what is needed in a tough use environment.
That worked fine for me also. I have no way of knowing if one is better than the other.
Great thread. I was thinking this weekend that I needed to change mine. Are you guys just sucking it out of the reservoir and refilling?
Also does power steering fluid have a shelf life? I have an unopened bottle of Valvoline Synthetic thats probly a good 6 years old. Think I would be ok using it?
I haven't had to suck it out last year it blew out all over the track!
I had a gut bring a bottle of PS fluid & gave it to me before a race & told me to just go out on the track & pour it out & save all of us some time.
Now as I do the brake fluid I will suck it out of the reservor & refill.
I don't know if it has a shelf life but if it was never opened I would think it would be OK but if it was opened 6 years ago, I would toss it & but new. Just my 2 cents.
St. Jude Donor '10-'11
Went from Valvoline synthetic blend to RedLine and now to Amsoil (RedLine most commonly recommended) I do ~ 8 track days a year, about 8 autox days a year, and two time trial days a year.
