FS New T1 Transmission Oil cooler Kit
Old 03-31-2009, 08:03 PM
Robert@RSD
Robert@RSD's Avatar
Default FS New T1 Transmission Oil cooler Kit
This is a GM Performance Part. It is part of the complete T1 kit the part number is 12480080.
C5 Transmission Oil Cooler Kit 12480080
C5 Transmission Oil Cooler Kit 12480080 Description
12480080 C5 Transmission Oil Cooler Kit This kit is intended for cars equipped with the six-speed manual transmission and has been updated for use on Z06 and export-model C5 Corvettes. Kit includes transmission pump, cooler assembly, wiring harness, plumbing kit, filter bracket, thermal switch, brackets and fasteners.
Retail is 1384.00
Dealer COST is 975.13
I will sell Brand new in box for 800 Shipped to the 48.
Old 04-01-2009, 02:57 AM
rustyguns
rustyguns's Avatar
tempting
Old 04-01-2009, 08:05 PM
Robert@RSD
Robert@RSD's Avatar
Originally Posted by rustyguns
tempting
go for it
Old 04-04-2009, 10:19 PM
Robert@RSD
Robert@RSD's Avatar
Bump....
Old 01-13-2014, 02:11 PM
oviz06
oviz06's Avatar
Retail is 1384.00
DO you have anotherone of these or know somebody who does?
Old 01-18-2014, 12:48 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,919 Likes on 5,328 Posts
You can make one yourself that includes most of the same elements or use a kit from DRM or similar forum vendor. DRM kit may be less costly. The GM kit pumps the transmission fluid to the front of the car where it is cooled in a Fluidyne Stacked Plate cooler that is mounted in front of the radiator. They use a Weldon pump. The cooler is themostatically controlled by a thermostat that is attached to one of the fins on the transmission case.
They use a 3/8 pressure rated hose that goes through the right side rocker panel to get the fluid to the cooler. Pump is hard mounted to the frame on the passenger side behind the rear wheel well liner and above the area where a Z06 rear brake duct runs. There are some issues with this lay out and I recommend you also investigate a DRM cooler.
Bill
Old 01-20-2014, 05:52 PM
oviz06
oviz06's Avatar
Bill
Bill, Thanks for the information. The DRM kit has a pump and a radiator but doesn't have a fan. How does it cool the fluid then since it's inside the wheelwell? Where is the airflow coming from?
Old 01-20-2014, 07:38 PM
fatbillybob
fatbillybob's Avatar
Bill
Has anyone figured out how much extra oil volume is needed? Or does everyone just run stock max oil height?
Old 01-21-2014, 11:01 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
We are using a the Z06 brake scoop. There is plenty of air flow to the cooler using that spot!!!
Randy
To FS New T1 Transmission Oil cooler Kit
Quick Reply: FS New T1 Transmission Oil cooler Kit
