Installing race seats in a c6, issues??
I recently purchased some cobra suzuka race seats for the c6 lt1. I plan on removing all factory mounts and using the pfadt universal mounts mounted to the floor. However I will be using standard seat belts when driving on the road and not at hdpe events.
Are there going to be any issues? Lights on the dash, seatbelt issues etc? Solutions? When I did this to the 350z it seemed much more simple....
If you have a roll cage or bar that is above your head you should be ok. If not you do not want as race seat as you cannot get down on the console in a roll over with a racing seat like you can the stock seat with the three peice belt.
Issues:
1. Where you would bolt the 3 point is directly in line with the harness mounting point.
2. Hard to find the receiver side. Because of the size, you may need to buy a replacement with the pretensioner.
3. You will see a red air bag light.
4. Telescoping steering wheel as noted earlier.
5. The guys at PFADT do not recommend running like this because the 3 point was designed a part of the air bag system.
1 Post
Cruise-In II Veteran
The Hardbar seat rails are the standard setup that almost every T1 car in the country has, and have won every SCCA Runoffs that Corvettes have won that last few years. The installation is simple and straight forward and have infnite adjustability, have more headroom than any others by at least 3-4 inches (although you can go a high as you want) and are the strongest on the market by a long shot. They do allow the stock seat belts as well. We also have a electrical harness that will fix the lights. Please check put the installation instructions to see how they work.
http://hardbarusa.com/uploads/image/...lv1%206(1).pdf
Here are some pics of a Cobra Suzuka in Chris Ingle's SE Division Championship T1 class C6.
Chris is very tall!
http://hardbarusa.com/hardbar/produc...products_id=45
Chris is very tall!
Issues:
Those look great. I really would like to keepmy standard belts for street driving as a 6-point is just too much to deal with.
Chris is very tall!
Chris is very tall!
You need to put the right amount of resistance across the connectors that plug into the OEM seat. This "fools" the car into thinking the OEM seat is still in the car, and the seat belt light will not stay on once you start the car. Pfadt may have a plug in devices with built in resistors. Give them a call.
Just spoke to pfadt. That telescoping jumper will work only if I don't remove the passanger seat (which of course I plan on doing). Pfadt said there really isn't a hard solution to get rid of the light once the passanger seat is out.
Good to know. One of these days I will pull the passenger seat to save some weight while on track.
From what i have seen the slider rails raise the seat too high for helmet use if you are taller.
Subesports (a big cobra seat dealer) says i can disable the passenger seat airbag unit but everyone else says that isnt true. I need to find a skillfull shop in texas to do these seats for me. Im worried this is far more complicated than i thought it would be
1 Post
That is one of the reasons we don't make slider rails. Sliders cost you real estate, no matter what and are not as stiff and secure. With our rails you are intimate with the car and you can drop most seats almost on the floor. With Vetteworks, we have a new harness for the light issue and you can pull the fuse on the airbags as well (T1 guys have to). This is not a big deal, you can do this. In addition, once you have the seat how you like it with our setup, it is a 10-15 minute changeout from one seat to the other. Use the track seats at the track, street seats on the street, no biggie.
FYI, the rails above for Chris were were extensively "Swiss cheesed" for weight savings, and powdercoated white to go with the custom Teamtech harness. They are very pretty for sure, even if Chris isn't!
I run my C6Z with the light on and it does not effect it's performance. I would not run it on the street like that, as if you get into an accident and the airbags don't delpoy, it is NOT worth the risk. There is also no proof that the resistor makes the air bags work correctly, so you are taking your chances. It is more work, but I change the seat out. Since they are all pre-set, it takes 20 minutes before each event.
I had the driver's seat out of my old Porsche Boxster S once, and made the mistake to turn the ignition on while the seat was disconnected. The computer sensed the missing airbag, and it required a visit to the dealer (and $100) to have the stupid airbag light reset...
EDIT - This question is specific to a C6, since a C5 computer may react differently...
Rule #1, anytime you disconnect OEM electrical connections, disconnect the battery (but set your telescoping wheel before you disconnect the battery). I disconnect and reconnect my seat on a monthly basis and the light goes out each time I reconnect the OEM seat.
I would just like to say thank you very much for all of the help you guys have given me. I'm definitely buying the hardbar mounts. As for the passanger seat resistor any have a how to or pictures before I get knee deep in this? No one in Austin seems to know how to do it.
And to be honest - it was a professional mechanic that turned the ignition on with the seat & wiring disconnected. He denied having done that, so I got stuck with the computer reset bill of $100.
I swap my seats frequently, never disconnect the battery and have had no issues. As to the functionality of the air bags once the OEM seat is out, maybe they will deploy, maybe not. I would not stake my life on it. GM crash tested the OEM system. I doubt you can say that for any aftermarket company. And yes, the warning light does come on when you remove the OEM seat, even if you have the 1LT (which I do), probably because there is an air bag sensor attached to the OEM seat.
